Re: Is 3" exhaust too much?
[Re: DirectSubjection]
#487058
10/03/09 06:23 PM
10/03/09 06:23 PM
RapidRobert
I think anytime a header collector reducer is constricting the flow that power is being left on the table. A 3" system as said is much louder & correct muffs, an X pipe and resonators downstream would be mandatory.
[Re: CFster]
#487060
10/03/09 06:59 PM
10/03/09 06:59 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
Had a 3" TTI H-pipe system and it was too freeking loud (as in drone). Changed to a 2.5" X-pipe system and it seems to have more low end torque as well.
Colin, Love the car! Nice color combo, too.
[Re: 64Post]
#487063
10/03/09 07:26 PM
10/03/09 07:26 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I was about to comment about how good your 64 looks & saw 64Post had beaten me to it.. Good lookin car, the color & wheel choice both work well..
[Re: CFster]
#487066
10/03/09 07:54 PM
10/03/09 07:54 PM
Posts: 1,373 Rancho Cucamonga, CA
D_C
Hmmm... Ideally, you would run open exhaust with optimized length collectors. Generally speaking, the less restrictive the system, the better. Sometimes Low-end torque is slightly improved by a more restrictive system. There are systems I have read about the purportedly produce more power with X-Pipes and optimized, tuned mufflers, etc. Still, less restrictive is typically the better way to go. I own a '79 Jeep CJ5 with AMC 304 V8. I run 3-inch pipes and Dynomax Mufflers on it. It's not quiet, but not overly loud either. I also own a '71 Charger. When I upgraded from 2 1/2-inch to 3 1/2-inch exhaust on the 440 in it, 1/4-mile ET performance improved by 7/10-second.
[Re: Evil Spirit]
#487068
10/03/09 08:31 PM
10/03/09 08:31 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Here is a page from Magnaflows web site. One thing to consider also is the difference in mandrel bends and the typical exhaust shop bends that have the wrinkles in the bends. A 3" system that has kinks and wrinkles in the bends will not outflow a good mandrel bent 2.5" system.
Free advice and worth every penny... Factory trained Slinky rewinder.........
