edm lifter question #485126
10/01/09 01:35 PM
10/01/09 01:35 PM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
Hello, do you have to remove the inner springs for cam break in when using an EDM style lifter on a mild flat tappet cam. (560 lift 240 @.050 range) Thanks in advance
Re: edm lifter question [Re: 70VcodeCoronetRT] #485127
10/01/09 02:24 PM
10/01/09 02:24 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Do you want to get this wrong?? Why risk it...
It has more to do with spring pressure than anything else.. typiclly if you have over 300 lbs @ full lift it is required.. But personally I would tend to be conservative & remove them even if the cam only sees 280ish over the nose...
Re: edm lifter question [Re: 1_WILD_RT] #485128
10/01/09 02:27 PM
10/01/09 02:27 PM
Az
Crizila Offline
Crizila  Offline
Az
That's a big 10-4.
Fastest 300
Re: edm lifter question [Re: 70VcodeCoronetRT] #485129
10/01/09 02:28 PM
10/01/09 02:28 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Largely depends on the open pressure. FWIW I wiped a lobe using std. lifters with 350# open both springs installed. I pulled the inner spring on the subsequent break in
Do you have to? No. Should you? Yes, absolutely. It's your motor though...
Re: edm lifter question [Re: 64Post] #485130
10/01/09 02:37 PM
10/01/09 02:37 PM
Az
Crizila Offline
Crizila  Offline
Az
Hughes recommends it with all their dual spring applications.
Fastest 300
Re: edm lifter question [Re: Crizila] #485131
10/01/09 02:47 PM
10/01/09 02:47 PM
Nebraska
Nebraska
OK, thanks. Might have to bite the bullet and go roller then.
Re: edm lifter question [Re: Crizila] #485132
10/01/09 02:49 PM
10/01/09 02:49 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Yeah John, I know if it were my engine I'd pull the inner springs regardless of the open pressure.
Re: edm lifter question [Re: 70VcodeCoronetRT] #485133
10/01/09 03:09 PM
10/01/09 03:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Why, because you have to pull the inner springs on break in ?
Re: edm lifter question [Re: JohnRR] #485134
10/01/09 03:23 PM
10/01/09 03:23 PM
scratchnfotraction Offline
I went roller for no break in on the cam
I also have 3 roller cams to play with,makes it easy to upgrade to next bigger one or step down one,dont have to keep the roller lifter in any speacal order either..
but thats me under the shadetree,I read to many post on here about wiping cam lobes and was a nervos nelly with my new engine combo
