Re: edm lifter question
[Re: 70VcodeCoronetRT]
#485129
10/01/09 02:28 PM
10/01/09 02:28 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
Hello, do you have to remove the inner springs for cam break in when using an EDM style lifter on a mild flat tappet cam. (560 lift 240 @.050 range) Thanks in advance
Largely depends on the open pressure. FWIW I wiped a lobe using std. lifters with 350# open both springs installed. I pulled the inner spring on the subsequent break in
Do you have to? No. Should you? Yes, absolutely. It's your motor though...
[Re: 64Post]
#485130
10/01/09 02:37 PM
10/01/09 02:37 PM
Posts: 7,506 Az
Crizila
Az
Hughes recommends it with all their dual spring applications.
Fastest 300
[Re: Crizila]
#485132
10/01/09 02:49 PM
10/01/09 02:49 PM
64Post
Baltimore/Denver
Yeah John, I know if it were my engine I'd pull the inner springs regardless of the open pressure.
#485133
10/01/09 03:09 PM
10/01/09 03:09 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
OK, thanks. Might have to bite the bullet and go roller then.
Why, because you have to pull the inner springs on break in ?
[Re: JohnRR]
#485134
10/01/09 03:23 PM
10/01/09 03:23 PM
Posts: 15,487 Florida
scratchnfotraction
I went roller for no break in on the cam I also have 3 roller cams to play with,makes it easy to upgrade to next bigger one or step down one,dont have to keep the roller lifter in any speacal order either.. but thats me under the shadetree,I read to many post on here about wiping cam lobes and was a nervos nelly with my new engine combo
