roller lifter life #482945
09/28/09 08:13 PM
09/28/09 08:13 PM
CEDAR RAPIDS
Plymouth340 Offline OP
CEDAR RAPIDS
How long do you guys run your roller lifters before replacing then? last time i went 600 passes and one broke amagine that. so now i have the intake off to put on the tunnel ram and all the lifter seem fine......and i am at 300 runs and run the motor to 7400rpm in every gear...thanks for your advise in advance...
Re: roller lifter life [Re: Plymouth340] #482946
09/28/09 11:02 PM
09/28/09 11:02 PM
there's no set rule, or limit. it really depends on the cycles, spring pressures, rpm etc. lack of enough spring pressure is a lifter killer too. obviously you know not to go 600 runs again though.
Re: roller lifter life #482947
09/28/09 11:30 PM
09/28/09 11:30 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
I have been removing stuff out of service while it is still good , before it goes bad.
You run the parts at the beginning of their life, but you start taking chances at the end of their life.
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: roller lifter life [Re: Plymouth340] #482948
09/29/09 11:45 AM
09/29/09 11:45 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ve been street driving and have made a couple hundred passes on my Isky solid body lifters and they seemed good last time I checked em. Guess I`m pushing my luck..............
Re: roller lifter life [Re: Thumperdart] #482949
09/30/09 01:03 AM
09/30/09 01:03 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
If your lash starts to change, there is a reason for it. Keeping an eye on the valve lash has prevented me from total lifter/cam failures.
Plynouth VIP '67 TT IC EFI
