How long do you guys run your roller lifters before replacing then? last time i went 600 passes and one broke amagine that. so now i have the intake off to put on the tunnel ram and all the lifter seem fine......and i am at 300 runs and run the motor to 7400rpm in every gear...thanks for your advise in advance...
