Getting M/T ET drags 28x9x15 to fit 68 dart? #482243
09/28/09 08:43 AM
09/28/09 08:43 AM
S.E. Minnesota
gtsdude Offline OP
gtsdude  Offline OP
S.E. Minnesota
I got these slicks to run on my dart, wheel lip on driver side is rubbing and a little on passenger side. I have them mounted on 15x8 cop wheels, is there any other wheel that anyone has used to get these tires in there without rubbing? I really hate to roll the lip on the wheel well.
Re: Getting M/T ET drags 28x9x15 to fit 68 dart? [Re: gtsdude] #482244
09/28/09 10:58 AM
09/28/09 10:58 AM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Are the springs moved? Car mini tubbed?
Re: Getting M/T ET drags 28x9x15 to fit 68 dart? [Re: 340_Dart] #482245
09/28/09 11:10 AM
09/28/09 11:10 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have them on my 69, the springs are moved in 3/4", the rear is moved back 1/2". They're on 15 X 8 Welds with a 5.5" back space.
Re: Getting M/T ET drags 28x9x15 to fit 68 dart? [Re: justinp61] #482246
09/28/09 11:18 AM
09/28/09 11:18 AM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
I run 26x9.5 on my 69 dart with the summit brand stars with only a 4" backspacing and the passenger side rubs the fender in hard right turns. My suspension is all stock. I didnt roll the fender lip but I did grind the lip and the trim piece slightly,or else I would have cut a brand new tire to shreds. As it is it rubs every now and then. If you get the correct back spacing on the wheels you should be fine.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: Getting M/T ET drags 28x9x15 to fit 68 dart? [Re: gtsdude] #482247
09/28/09 11:22 AM
09/28/09 11:22 AM
Cab_Burge Online work
Cab_Burge  Online Work
Hoiw much room do you have on the inside and on the front lower edge of the wheelwell edge by the rocker panels?
Re: Getting M/T ET drags 28x9x15 to fit 68 dart? [Re: G-Money1320] #482248
09/28/09 11:24 AM
09/28/09 11:24 AM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
On my 69 Dart with an A-body 83/4 and the spings moved in 3/4". I used Weld Draglites with 4.5" BS. I did have to trim the wheel lip a small amout just for safety sake. Jim
Re: Getting M/T ET drags 28x9x15 to fit 68 dart? [Re: rt66jim] #482249
09/28/09 11:48 AM
09/28/09 11:48 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
For some reason, the factory didn't center the rear axles between the fenderwells. Every Dart I've looked at had less tire clearance on one side.
Floyd Lippencott IV
Re: Getting M/T ET drags 28x9x15 to fit 68 dart? [Re: mr_340] #482250
09/29/09 09:07 AM
09/29/09 09:07 AM
S.E. Minnesota
gtsdude Offline OP
gtsdude  Offline OP
S.E. Minnesota
I have a half inch in front of the tire and passenger side i have half inch between the lip and tire and driver side i have almost none, at least i cant get a finger in there.
Re: Getting M/T ET drags 28x9x15 to fit 68 dart? [Re: gtsdude] #482251
09/30/09 12:33 AM
09/30/09 12:33 AM
That is NOT unusual Dang Ma Mopars quality control folks How much room do you have on the inside of the drivers side? Do you know if you have the stock spring perches on the rear end or aftermarket ones? If stock you may not be able to move the rear end over towards the passenger side by loosening and readjusting the springs on the spring perches, some aftermarket perches have a bigger hole in the middle where the spring center bolt rides and you can slide them forward or backwards and side to side some, not a big amount, 1/4 to 3/8 inches maybe )
Re: Getting M/T ET drags 28x9x15 to fit 68 dart? [Re: justinp61] #482252
09/30/09 12:56 AM
09/30/09 12:56 AM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
This is EXACTLY what I did for my wifes 69 Dart. Fits perfect. The 3/4 inch spring relocation is a necessity.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: Getting M/T ET drags 28x9x15 to fit 68 dart? [Re: PUNK] #482253
09/30/09 10:36 AM
09/30/09 10:36 AM
S.E. Minnesota
gtsdude Offline OP
gtsdude  Offline OP
S.E. Minnesota
Yeah, I am going to try to see if any way to at least slide over to center it. Driver side wheel lip is almost touching, maybe get a piece of paper in there if i am lucky. It has super stock springs, not sure on the rear spring perches, it had the springs in when i bought the car. I think I am just going to do the 3 inch spring move. Then I can get some real tires and wheels in there.
Re: Getting M/T ET drags 28x9x15 to fit 68 dart? [Re: gtsdude] #482254
09/30/09 12:32 PM
09/30/09 12:32 PM
When in doubt, fix it
