Re: Getting M/T ET drags 28x9x15 to fit 68 dart?
[Re: justinp61]
#482246
09/28/09 11:18 AM
09/28/09 11:18 AM
Posts: 1,675 Mi.
G-Money1320
Mi.
I run 26x9.5 on my 69 dart with the summit brand stars with only a 4" backspacing and the passenger side rubs the fender in hard right turns. My suspension is all stock. I didnt roll the fender lip but I did grind the lip and the trim piece slightly,or else I would have cut a brand new tire to shreds. As it is it rubs every now and then. If you get the correct back spacing on the wheels you should be fine.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out. 11.06 open headers----so far!!
[Re: gtsdude]
#482247
09/28/09 11:22 AM
09/28/09 11:22 AM
Posts: 43,141 Bend,OR USA
Cab_Burge
Hoiw much room do you have on the inside and on the front lower edge of the wheelwell edge by the rocker panels?
[Re: rt66jim]
#482249
09/28/09 11:48 AM
09/28/09 11:48 AM
Posts: 3,504 DFW
mr_340
DFW
For some reason, the factory didn't center the rear axles between the fenderwells. Every Dart I've looked at had less tire clearance on one side.
Floyd Lippencott IV
[Re: gtsdude]
#482254
09/30/09 12:32 PM
09/30/09 12:32 PM
Cab_Burge
Yeah, I am going to try to see if any way to at least slide over to center it. Driver side wheel lip is almost touching, maybe get a piece of paper in there if i am lucky. It has super stock springs, not sure on the rear spring perches, it had the springs in when i bought the car. I think I am just going to do the 3 inch spring move. Then I can get some real tires and wheels in there.
When in doubt, fix it
