Re: B&M flexplate for Magnum 360??
[Re: joedust451]
#477988
09/23/09 10:56 PM
09/23/09 10:56 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Application: ‘93-’99 Chrysler 360 w/TF727 Externally Balanced Dual Bolt Pattern (10" & 11-1/8") Item# 10242
that is the part number for the 727 flexplate for magnum....check the bolt circle on your 904 converter...if it is same as the 727 ...dont see why it would not fit...
magnum are externally balanced but not the same as LA 360s due to the lighter pistons and rods... magnum use less weight on converter and BALANCER...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: goldmember]
#477989
09/23/09 10:58 PM
09/23/09 10:58 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
Why not use the factory magnum flexplate with the weights on it? No you cannot use the LA B&M flexplate.
I couldn't find any weights on the magnum flexplate, am i missing something, its a 95 model.
I've heard about longating one of the holes for the 904, does it matter which hole?
[Re: 70AARcuda]
#477990
09/23/09 11:03 PM
09/23/09 11:03 PM
joedust451
super gas
super gas
Branson, Mo.
So i should be able to longate one of the holes on the B&M flexplate for the magnum 727, like i would have to do on the factory magnum flexplate right! Would this make sence? But if its for the 727, wouldn't the 904 converter bolt patterns be the same?
[Re: Intense RT Dan]
#477994
09/24/09 11:55 AM
09/24/09 11:55 AM
joedust451
super gas
super gas
Branson, Mo.
So, does the 904 & 727 converters have the same bolt pattern?? If so, don't see why the 10242 B&M Magnum 727 flexplate wouldn't work.
I called B&M, they HAD a 10241 flexplate for the 360 magnum with 904, but its been discontinued.
[Re: joedust451]
#477995
09/24/09 06:23 PM
09/24/09 06:23 PM
Posts: 377 Michigan Troll
blk00rt
Michigan Troll
I have one that I slotted the hole on. If you want it let me know. I changed to an LA motor instead. PM me if you are interested. Rob
Rob Dunn 1976 Dart Sport 360 2000 dakota RT 408 with 150 nitrous 2013 Dodge Ram 1500 Hemi 2009 Jeep Patriot
