B&M flexplate for Magnum 360?? #477985
09/23/09 10:47 PM
09/23/09 10:47 PM
Branson, Mo.
joedust451 Offline OP
super gas
super gas
Branson, Mo.
Help me out guys, according to jegs, B&M doesn't make a flexplate for the magnum engine, but i'm wanting to make it so i can run a "N" balanced converter (no weights), it'll be going behind a 904 tranny, can i just use the B&M flexplate for the LA 360 & 904??
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: B&M flexplate for Magnum 360?? [Re: joedust451] #477986
09/23/09 10:52 PM
09/23/09 10:52 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Why not use the factory magnum flexplate with the weights on it? No you cannot use the LA B&M flexplate.
Re: B&M flexplate for Magnum 360?? [Re: joedust451] #477987
09/23/09 10:54 PM
09/23/09 10:54 PM
Andrewh Offline
Andrewh  Offline
I have one for the 727,but am not aware of it for the 904.
Theoretically you could just slot a hole in it and make it work for the 904.
Re: B&M flexplate for Magnum 360?? [Re: joedust451] #477988
09/23/09 10:56 PM
09/23/09 10:56 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Application: ‘93-’99 Chrysler 360 w/TF727 Externally Balanced Dual Bolt Pattern (10" & 11-1/8")
Item# 10242
that is the part number for the 727 flexplate for magnum....check the bolt circle on your 904 converter...if it is same as the 727 ...dont see why it would not fit...
magnum are externally balanced but not the same as LA 360s due to the lighter pistons and rods...
magnum use less weight on converter and BALANCER...
Tony
70 AARCuda Vitamin C
Re: B&M flexplate for Magnum 360?? [Re: goldmember] #477989
09/23/09 10:58 PM
09/23/09 10:58 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
I couldn't find any weights on the magnum flexplate, am i missing something, its a 95 model.
I've heard about longating one of the holes for the 904, does it matter which hole?
Re: B&M flexplate for Magnum 360?? [Re: 70AARcuda] #477990
09/23/09 11:03 PM
09/23/09 11:03 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
Item# 10242
So i should be able to longate one of the holes on the B&M flexplate for the magnum 727, like i would have to do on the factory magnum flexplate right! Would this make sence? But if its for the 727, wouldn't the 904 converter bolt patterns be the same?
Re: B&M flexplate for Magnum 360?? [Re: joedust451] #477991
09/23/09 11:08 PM
09/23/09 11:08 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Some years they had the weight on the flexplate.Maybe 96up? You can gently slot the hole in the flexplate to work with the early style converters.Just put the flexplate/converter on the bench and you will find 1 hole needs a little adjustment.
Re: B&M flexplate for Magnum 360?? [Re: goldmember] #477992
09/23/09 11:20 PM
09/23/09 11:20 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
So, would anyone happen to have a flexplate with the weights they would let go cheap
Re: B&M flexplate for Magnum 360?? [Re: joedust451] #477993
09/24/09 01:58 AM
09/24/09 01:58 AM
Mooresville, NC
I
Intense RT Dan Offline
I
Mooresville, NC
I sent a b&m back to summit because I thought I could just take the weights off and put it on the balancer to check it. No weights, had a big crescent moon shaped piece cut out instead of adding weight on the other side. So, it was setup for external balance. I'm still efi and plan on running a 5.2 flexplate with the crank position sensor windows on the outside edge.
Not sure if this helps you or not. Good luck.
Re: B&M flexplate for Magnum 360?? [Re: Intense RT Dan] #477994
09/24/09 11:55 AM
09/24/09 11:55 AM
Branson, Mo.
super gas
super gas
Branson, Mo.
So, does the 904 & 727 converters have the same bolt pattern?? If so, don't see why the 10242 B&M Magnum 727 flexplate wouldn't work.
I called B&M, they HAD a 10241 flexplate for the 360 magnum with 904, but its been discontinued.
Re: B&M flexplate for Magnum 360?? [Re: joedust451] #477995
09/24/09 06:23 PM
09/24/09 06:23 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
I have one that I slotted the hole on. If you want it let me know. I changed to an LA motor instead. PM me if you are interested.
Rob
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: B&M flexplate for Magnum 360?? [Re: blk00rt] #477996
09/24/09 07:44 PM
09/24/09 07:44 PM
Ma, USA North of Boston
74SatSundance Offline
THis place still shows them as blowing them out.
PAW
If you do a search on 10241 flexplates you might find others that have leftover stocks.
Re: B&M flexplate for Magnum 360?? [Re: 74SatSundance] #477997
09/24/09 10:23 PM
09/24/09 10:23 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
blk00rt, sent you a PM
Thanks guys
