another electrical bug,another bad ground? #476435
09/22/09 09:04 AM
09/22/09 09:04 AM
weymouth,mass.
meepmeep70 Offline OP
weymouth,mass.
insrument/dash lights come on when i press brake pedal,another ground problem or do i have something crossed? thank you
Re: another electrical bug,another bad ground? [Re: meepmeep70] #476436
09/22/09 10:15 AM
09/22/09 10:15 AM
Andrewh Offline
Andrewh  Offline
could go either way. Bad ground at the tail lights, but I would expect the turn signals to light up in the dash, not the dash lights.
Might have a crossed wire or melted one somewhere.
Do your brake lights actually come one?
You would have to check common points. Like the light switch.
Re: another electrical bug,another bad ground? [Re: meepmeep70] #476437
09/22/09 11:07 AM
09/22/09 11:07 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
If one turn signal will light the dash lights, either right or left, that will help you locate which tailight to look at closely, socket or bulbwise.
Re: another electrical bug,another bad ground? [Re: buildanother] #476438
09/22/09 11:11 AM
09/22/09 11:11 AM
I would suspect crossed wire(s) rather than ground
Re: another electrical bug,another bad ground? [Re: RapidRobert] #476439
09/22/09 01:07 PM
09/22/09 01:07 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
check for bad contack at fuse block... fuse terminal loosen. The circuit could it be closing by a ground from another section positive source ( yes I know sounds some crazy but is true )
BTDT... I was getting once dome and map light dimmed on when pressing brake pedal and it was the fuse/terminal damaged, loosen, dirty etc..
Re: another electrical bug,another bad ground? [Re: meepmeep70] #476440
09/22/09 01:23 PM
09/22/09 01:23 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
I had a light show like that years ago on a Dodge Magnum. Oddly, a fuse check/replacement fixed the problem.
Re: another electrical bug,another bad ground? [Re: meepmeep70] #476441
09/22/09 01:27 PM
09/22/09 01:27 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
It could be either. You could be creating a ground path through the switch, or you could be tying two circuits together.
I would try rigging up a temporary ground for the instrument panel to check. Usually there is a screw/bolt on the back of most Mopar panels that can be used for a ground wire from the panel to a screw or bolt on the dash or firewall/floorpan. Look for a screw that shows copper running up to the screw hole. If you have the factory service manual or aftermarket schematic diagram you can find the ground(s) in the schematic and verify they are present with an ohm meter.
You can put a 5 amp or less fuse in the wire if you are afraid of causing a
Re: another electrical bug,another bad ground? [Re: Lefty] #476442
09/22/09 03:31 PM
09/22/09 03:31 PM
weymouth,mass.
weymouth,mass.
thanks i will try all the sugestions,i've been chasing some electrical gremlins,directionals work fine,but as soon as i have parking lights on the pass. directional just lights up bright with no flashing,drivers works good,lights off all work again.i'll report back after working on it some tonight. thank you guys
