Re: another electrical bug,another bad ground?
[Re: buildanother]
#476438
09/22/09 11:11 AM
09/22/09 11:11 AM
RapidRobert
I would suspect crossed wire(s) rather than ground
[Re: RapidRobert]
#476439
09/22/09 01:07 PM
09/22/09 01:07 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
check for bad contack at fuse block... fuse terminal loosen. The circuit could it be closing by a ground from another section positive source ( yes I know sounds some crazy but is true )
BTDT... I was getting once dome and map light dimmed on when pressing brake pedal and it was the fuse/terminal damaged, loosen, dirty etc..
[Re: meepmeep70]
#476441
09/22/09 01:27 PM
09/22/09 01:27 PM
Posts: 6,516 Santa Cruz, California
Lefty
insrument/dash lights come on when i press brake pedal,another ground problem or do i have something crossed? thank you
It could be either. You could be creating a ground path through the switch, or you could be tying two circuits together.
I would try rigging up a temporary ground for the instrument panel to check. Usually there is a screw/bolt on the back of most Mopar panels that can be used for a ground wire from the panel to a screw or bolt on the dash or firewall/floorpan. Look for a screw that shows copper running up to the screw hole. If you have the factory service manual or aftermarket schematic diagram you can find the ground(s) in the schematic and verify they are present with an ohm meter.
You can put a 5 amp or less fuse in the wire if you are afraid of causing a
[Re: Lefty]
#476442
09/22/09 03:31 PM
09/22/09 03:31 PM
Posts: 3,426 weymouth,mass.
meepmeep70
weymouth,mass.
thanks i will try all the sugestions,i've been chasing some electrical gremlins,directionals work fine,but as soon as i have parking lights on the pass. directional just lights up bright with no flashing,drivers works good,lights off all work again.i'll report back after working on it some tonight. thank you guys
