stock 440 valve covers #476205
09/21/09 10:12 PM
09/21/09 10:12 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
Will stock 69 440 valve covers work with Crane Gold rockers (1.5) on Edelbrock heads? Any clearance issues or do I need a taller cover?
Thanks,
Steve
Re: stock 440 valve covers [Re: srunge55] #476206
09/22/09 09:20 AM
09/22/09 09:20 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The rockers , at a minimum the adjusters , will hit the baffles in the cover, you'll need to raise the covers up , try doubling a gasket , if you want to keep your stock covers .
Re: stock 440 valve covers [Re: JohnRR] #476207
09/22/09 11:18 AM
09/22/09 11:18 AM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
That is what I was afraid of. Thanks.
Re: stock 440 valve covers [Re: srunge55] #476208
09/22/09 11:30 AM
09/22/09 11:30 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
does anyone make a spacer?
Re: stock 440 valve covers [Re: srunge55] #476209
09/22/09 11:30 AM
09/22/09 11:30 AM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
I have Comp pro magnums on my 500 with stock 440 covers and standard felpro gaskets. I did dimple the baffles just a little. They work fine for me.
Re: stock 440 valve covers [Re: srunge55] #476210
09/22/09 12:42 PM
09/22/09 12:42 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
I'm running '77 vintage covers with Harland-Sharps, 0.650" lift and standard cork gaskets. One still has the factory bar code on it. I did have to modify the end exhaust rockers but they have surplus material that shouldn't be there anyay. Measure the distance from the flange to the baffles and post it.
Cory
Re: stock 440 valve covers [Re: @#$%&*!] #476211
09/22/09 12:52 PM
09/22/09 12:52 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Cory
77 covers are alot taller than the 69 covers he is dealing with .
Re: stock 440 valve covers [Re: @#$%&*!] #476212
09/22/09 02:22 PM
09/22/09 02:22 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
I'll do that when I get home tonight. Thanks
Re: stock 440 valve covers [Re: srunge55] #476213
09/22/09 03:11 PM
09/22/09 03:11 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
You'll have to "work" the baffles to make them work
Coming soon!!!!
Re: stock 440 valve covers [Re: Mr.Yuck] #476214
09/22/09 04:48 PM
09/22/09 04:48 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Are you running aftermarket heads? This reason why I ask is I was told the golds would hit my sb 273 valve covers and they didn't, but........I'm running E-brock heads.
Moparlee
Re: stock 440 valve covers [Re: Robbins] #476215
09/22/09 05:11 PM
09/22/09 05:11 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
I am running edelbrock heads also. I guess I'll just have to mock it up and see.
Re: stock 440 valve covers [Re: srunge55] #476216
09/22/09 05:17 PM
09/22/09 05:17 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
I have 68-69 BB stock valve covers on my 505" with Stealth heads. They fit fine after hammering the baffles a bit.
2 kids and a dog
Re: stock 440 valve covers *DELETED* [Re: srunge55] #476217
09/22/09 05:56 PM
09/22/09 05:56 PM
Madison WI
Sublime69 Offline
Sublime69  Offline
Madison WI
Post deleted by Sublime69
1969 Dodge Superbee - Original plain jane green 318 Coronet now Sub-Lime, 383 4 speed clone.
Re: stock 440 valve covers [Re: Sublime69] #476218
09/22/09 06:43 PM
09/22/09 06:43 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
Great info, thanks. I will double check my measurements on my valve covers.
Re: stock 440 valve covers [Re: srunge55] #476219
09/22/09 08:24 PM
09/22/09 08:24 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
I have crane gold rollers on my iron 452 heads with stock 68 covers...no hamma needed! I doubt the eddie heads have a shorter flange than stock!
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: stock 440 valve covers [Re: srunge55] #476220
09/22/09 11:30 PM
09/22/09 11:30 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Running Crane Gold 1.6 rockers on 906 440 heads, 70 valve covers, had to remove the baffles for clearance,....no issuses with oil leaks or seepage or PVC oil draw being ecessive
Mike
