Re: stock 440 valve covers
[Re: @#$%&*!]
#476211
09/22/09 12:52 PM
09/22/09 12:52 PM
Posts: 75,058 U.S.S.A.
JohnRR
U.S.S.A.
I'm running '77 vintage covers with Harland-Sharps, 0.650" lift and standard cork gaskets. One still has the factory bar code on it. I did have to modify the end exhaust rockers but they have surplus material that shouldn't be there anyay. Measure the distance from the flange to the baffles and post it. Cory
77 covers are alot taller than the 69 covers he is dealing with .
[Re: Mr.Yuck]
#476214
09/22/09 04:48 PM
09/22/09 04:48 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
Are you running aftermarket heads? This reason why I ask is I was told the golds would hit my sb 273 valve covers and they didn't, but........I'm running E-brock heads.
Moparlee
[Re: srunge55]
#476216
09/22/09 05:17 PM
09/22/09 05:17 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
I have 68-69 BB stock valve covers on my 505" with Stealth heads. They fit fine after hammering the baffles a bit.
2 kids and a dog
Re: stock 440 valve covers *DELETED*
[Re: srunge55]
#476217
09/22/09 05:56 PM
09/22/09 05:56 PM
Posts: 165 Madison WI
Sublime69
Madison WI
Post deleted by Sublime69
1969 Dodge Superbee - Original plain jane green 318 Coronet now Sub-Lime, 383 4 speed clone.
[Re: srunge55]
#476219
09/22/09 08:24 PM
09/22/09 08:24 PM
Posts: 4,872 connecticut
pnypwr
connecticut
I have crane gold rollers on my iron 452 heads with stock 68 covers...no hamma needed! I doubt the eddie heads have a shorter flange than stock!
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
[Re: srunge55]
#476220
09/22/09 11:30 PM
09/22/09 11:30 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Running Crane Gold 1.6 rockers on 906 440 heads, 70 valve covers, had to remove the baffles for clearance,....no issuses with oil leaks or seepage or PVC oil draw being ecessive
Mike
