Re: Hemi Racers RPM [Re: RAT PATROL] #475346
09/22/09 05:05 PM
09/22/09 05:05 PM
New Jersey
Craig Offline
Craig  Offline
New Jersey
Launch off idle at 1500, check track position (you know up against the wall, on the centerline, well I'm preaching to the choir here) Shift when wheels touch, then shift again when that funny little yellow light comes on (that second shift is for the Mopar only crowd), cross the line at 7700. Was I suppose to look at the tach before the finish line?
That's my secret driving technique who let the cat out of the bag??
67 Dart, 426 Hemi, 9.23/145mph, 3400lbs, footbraked, owned since 1982
Post deleted by Defbob [Re: Craig] #475347
09/22/09 05:13 PM
09/22/09 05:13 PM
Anonymous OP
Anonymous OP
Re: Hemi Racers RPM #475348
09/22/09 07:52 PM
09/22/09 07:52 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
tire tracks like my pass here
My way works better,wheels up and straight down the track.No riding the guide rail or squiggly tire tracks.
Re: Hemi Racers RPM [Re: B G Racing] #475349
09/22/09 08:10 PM
09/22/09 08:10 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
foot brake 1500/1700rpm shift at7600rpm through traps 9200rpm
3046lbs 488 gears kb engine mechancal hillbron troquefight
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: Hemi Racers RPM [Re: 1969gtx] #475350
09/22/09 10:13 PM
09/22/09 10:13 PM
N of Detroit
DaveDudek Offline
DaveDudek  Offline
N of Detroit
I launch at 2200ish, shift at 7500, through the traps at 7900/8000ish.
Dave Dudek
1st Factory Stock legal car in the 10`s!!! [/b]
FAST & Factory Stock Rules: www.fastraces.org
FAST 69 Hemi RR 9.98@139
Post deleted by Defbob [Re: B G Racing] #475351
09/22/09 11:04 PM
09/22/09 11:04 PM
Anonymous OP
Anonymous OP
Re: Hemi Racers RPM #475352
09/23/09 07:33 AM
09/23/09 07:33 AM
Anonymous OP
Anonymous OP
What do the SS Hemi guys shift there cars at?
Re: Hemi Racers RPM #475353
09/23/09 08:47 AM
09/23/09 08:47 AM
Calif, USA
V
viperrt Offline
viperrt  Offline
V
Calif, USA
Trying to post a pic for the first time!
Re: Hemi Racers RPM #475354
09/23/09 01:20 PM
09/23/09 01:20 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
But I get to look out the side window and see more than you do
I got a look out of my side window at BSD this year and didn't like it
Re: Hemi Racers RPM [Re: B G Racing] #475355
09/23/09 05:45 PM
09/23/09 05:45 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Was that the pass with Ken,Your wheels 4 feet in the air and he hasn't moved yet!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Hemi Racers RPM [Re: hemi-itis] #475356
09/23/09 08:02 PM
09/23/09 08:02 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
No that was a picture perfect run,I was AJ Casini high at the 60'.My last run against the Ford Fairlane I went toward the grass back peddeled straightened out,pulled second and found myself looking straight down track through the side window,I peddled pulled high gear straghtened it out,stabbed it to the floor ran a low 10 at 139 but the Ford still had me at the stripe.It was the same lane that killed Chris,Ronny McCelland and about 5 others before they stopped the race to tune up the starting line.Of course it was nothing like Chaz on Sat.night wheelstand the 65 into Ronny McC's lane and the two running the full 1/4 in the same lane.
Post deleted by Defbob [Re: B G Racing] #475357
09/23/09 10:01 PM
09/23/09 10:01 PM
Anonymous OP
Anonymous OP
Post deleted by Defbob #475358
09/23/09 10:05 PM
09/23/09 10:05 PM
Anonymous OP
Anonymous OP
Re: Hemi Racers RPM #475359
09/23/09 10:33 PM
09/23/09 10:33 PM
Northeast, Arkansas
Dodgeman67 Offline
Dodgeman67  Offline
Northeast, Arkansas
Fred, I don't that you were doing it right on that pass?
Not an expert, but you're doing it wrong.
Post deleted by Defbob [Re: Dodgeman67] #475360
09/23/09 10:38 PM
09/23/09 10:38 PM
Anonymous OP
Anonymous OP
Re: Hemi Racers RPM #475361
09/23/09 10:48 PM
09/23/09 10:48 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Old SS motor, launch was around 6000-6500 with a stick and shifted at 9000-9200,went into the traps at 9800+. New mild street motor in car based on 68 SS/Factory stock motor out of A body, Launch as hard as street tires car handle, shift at 7800. Both motors built on the stock specs of the crank,no stroked crank.
1971 HEMI E BODY REGISTRY
Post deleted by Defbob [Re: hemicar1971] #475362
09/23/09 11:28 PM
09/23/09 11:28 PM
Anonymous OP
Anonymous OP
Re: Hemi Racers RPM #475363
09/24/09 05:42 AM
09/24/09 05:42 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Fred. Car has 538s and back in the Seventies the transmission had Doug Nash internals in a Chrysler Box,can not remember the first gear ratio, but it had a lot higher number than a stock Chrysler Box.
