Re: Hemi Racers RPM
[Re: RAT PATROL]
#475346
09/22/09 05:05 PM
09/22/09 05:05 PM
Posts: 642 New Jersey
Craig
New Jersey
Launch off idle at 1500, check track position (you know up against the wall, on the centerline, well I'm preaching to the choir here) Shift when wheels touch, then shift again when that funny little yellow light comes on (that second shift is for the Mopar only crowd), cross the line at 7700. Was I suppose to look at the tach before the finish line?
That's my secret driving technique who let the cat out of the bag??
67 Dart, 426 Hemi, 9.23/145mph, 3400lbs, footbraked, owned since 1982
Post deleted by Defbob
[Re: Craig]
#475347
09/22/09 05:13 PM
09/22/09 05:13 PM
Re: Hemi Racers RPM
#475348
09/22/09 07:52 PM
09/22/09 07:52 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
tire tracks like my pass here
My way works better,wheels up and straight down the track.No riding the guide rail or squiggly tire tracks.
Re: Hemi Racers RPM
[Re: B G Racing]
#475349
09/22/09 08:10 PM
09/22/09 08:10 PM
Posts: 643 southern conn
1969gtx
southern conn
foot brake 1500/1700rpm shift at7600rpm through traps 9200rpm 3046lbs 488 gears kb engine mechancal hillbron troquefight
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
Re: Hemi Racers RPM
[Re: 1969gtx]
#475350
09/22/09 10:13 PM
09/22/09 10:13 PM
Posts: 1,894 N of Detroit
DaveDudek
N of Detroit
I launch at 2200ish, shift at 7500, through the traps at 7900/8000ish.
Dave Dudek 1st Factory Stock legal car in the 10`s!!! [/b] FAST & Factory Stock Rules: www.fastraces.org FAST 69 Hemi RR 9.98@139
[Re: B G Racing]
#475351
09/22/09 11:04 PM
09/22/09 11:04 PM
Re: Hemi Racers RPM
#475352
09/23/09 07:33 AM
09/23/09 07:33 AM
What do the SS Hemi guys shift there cars at?
Re: Hemi Racers RPM
#475354
09/23/09 01:20 PM
09/23/09 01:20 PM
B G Racing
Eighty Four, PA
But I get to look out the side window and see more than you do
I got a look out of my side window at BSD this year and didn't like it
[Re: B G Racing]
#475357
09/23/09 10:01 PM
09/23/09 10:01 PM
#475358
09/23/09 10:05 PM
09/23/09 10:05 PM
[Re: Dodgeman67]
#475360
09/23/09 10:38 PM
09/23/09 10:38 PM
Re: Hemi Racers RPM
#475361
09/23/09 10:48 PM
09/23/09 10:48 PM
Posts: 5,118 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Old SS motor, launch was around 6000-6500 with a stick and shifted at 9000-9200,went into the traps at 9800+. New mild street motor in car based on 68 SS/Factory stock motor out of A body, Launch as hard as street tires car handle, shift at 7800. Both motors built on the stock specs of the crank,no stroked crank.
1971 HEMI E BODY REGISTRY
[Re: hemicar1971]
#475362
09/23/09 11:28 PM
09/23/09 11:28 PM
Re: Hemi Racers RPM
#475363
09/24/09 05:42 AM
09/24/09 05:42 AM
hemicar1971
Chicago Blackhawks
Fred. Car has 538s and back in the Seventies the transmission had Doug Nash internals in a Chrysler Box,can not remember the first gear ratio, but it had a lot higher number than a stock Chrysler Box.
