Post deleted by Defbob #475326
09/21/09 12:22 PM
09/21/09 12:22 PM
Anonymous OP
Anonymous OP
Re: Hemi Racers RPM #475327
09/21/09 12:38 PM
09/21/09 12:38 PM
Stratford,Ct
7sec.cuda Offline
7sec.cuda  Offline
Stratford,Ct
launch at 7200
shift at 9500
traps at 10,000 (dont be scared)
3000#
Post deleted by Defbob [Re: 7sec.cuda] #475328
09/21/09 12:48 PM
09/21/09 12:48 PM
Anonymous OP
Anonymous OP
Re: Hemi Racers RPM #475329
09/21/09 03:33 PM
09/21/09 03:33 PM
New Jersey
Craig Offline
Craig  Offline
New Jersey
Hey Fred, I footbrake 2000-3000, not sure where converter flashes but probably 6000, shift about 7200, trap about 7400. .030 over 69 block 4.15 crank (477 cid), Hilborn stacks on alky, torqueflite, 4.56 Dana.
67 Dart, 426 Hemi, 9.23/145mph, 3400lbs, footbraked, owned since 1982
Re: Hemi Racers RPM [Re: Craig] #475330
09/21/09 04:26 PM
09/21/09 04:26 PM
Kansas City Metro
mbogina Offline
mbogina  Offline
Kansas City Metro
Leave at 3700, convertor stall 64-6600, shift at 83-8500, traps at 8600, 438 CI, 3630 lbs, 5.57 gear, 14 x 33 radials
Be a Rebel- Break the Laws of Physics!
Re: Hemi Racers RPM [Re: mbogina] #475331
09/21/09 05:17 PM
09/21/09 05:17 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Hell, I run my Street Hemi to 7500 before pulling the next gear, and it's basically a street car.
Re: Hemi Racers RPM [Re: 7sec.cuda] #475332
09/21/09 07:07 PM
09/21/09 07:07 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
launch at 7200
shift at 9500
3000#
Re: Hemi Racers RPM [Re: 7sec.cuda] #475333
09/21/09 07:58 PM
09/21/09 07:58 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
launch at 7200
shift at 9500
3000#
Re: Hemi Racers RPM [Re: Dragula] #475334
09/21/09 08:50 PM
09/21/09 08:50 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
launch at 7200
shift at 9500
3000#
LOL He's cheating, thats a Pro Stock Hemi and thats where they make power.....
Re: Hemi Racers RPM [Re: TS3303] #475335
09/21/09 08:55 PM
09/21/09 08:55 PM
Northeast, Arkansas
Dodgeman67 Offline
Dodgeman67  Offline
Northeast, Arkansas
This will be my first hemi, so I don't have that information yet.
Someone is supposed to be gathering up me some part?
7 sec. cuda, 10,000 RPM, man that is turning it.
Post deleted by Defbob [Re: Dodgeman67] #475336
09/21/09 09:00 PM
09/21/09 09:00 PM
Anonymous OP
Anonymous OP
Re: Hemi Racers RPM #475337
09/21/09 10:23 PM
09/21/09 10:23 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Launch at 5500, shift at 7800, traps at 8000.
kelloge crank, Stock Steel rods(good bolts and polished beams), Venolia Pistons, crane R-290 roller, Stock Iron heads, weiand Tunnel ram w pr 660 Holleys. Best time 9.73@145 mph
2900lbs, 727, Dana w/5.13's
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Hemi Racers RPM [Re: W.I.N. Racing] #475338
09/21/09 10:25 PM
09/21/09 10:25 PM
Byron, NY
Byron, NY
aprox 1993
'60 Willys CJ5
Post deleted by Defbob #475339
09/21/09 10:32 PM
09/21/09 10:32 PM
Anonymous OP
Anonymous OP
Re: Hemi Racers RPM #475340
09/21/09 10:51 PM
09/21/09 10:51 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
but that's kinda a vague question isn't it Fred? the rpm depends on a lot of variables. iirc the cuda turning 10k has a prostock style engine in it which is a far cry from a 426 and using SS or blown alky cars as an example doesn't compare to what most guys build either. twisting an engine faster isn't always a good idea especially if you're past the peak HP.
Post deleted by Defbob [Re: jamesc] #475341
09/22/09 12:47 AM
09/22/09 12:47 AM
Anonymous OP
Anonymous OP
Re: Hemi Racers RPM #475342
09/22/09 12:50 AM
09/22/09 12:50 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Man I guess I was really a whimp with mine. We spent a lot of time testing and playing with my old Hemi at the track .Best results were shifting a 6400 and going throgh the lites at 7250. Car went the qucikest this was at 8.77 at 154. Was a 572" Hemi with Stage V heads.
Re: Hemi Racers RPM [Re: Al_Alguire] #475343
09/22/09 07:42 AM
09/22/09 07:42 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Launch at 2500/3000,shift at 6400/6800 and trap at 6900/7100 depending on if I foot brake or use the transbrake.
Re: Hemi Racers RPM [Re: B G Racing] #475344
09/22/09 07:45 AM
09/22/09 07:45 AM
an8sec70cuda Offline
Footbrake to 1500-1700 rpm, shift at 6700-6800, cross the stripe at 7200. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Hemi Racers RPM #475345
09/22/09 10:39 AM
09/22/09 10:39 AM
Oregon,USA
RAT PATROL Offline
RAT PATROL  Offline
Oregon,USA
Launch off idle at 1500, check track position (you know up against the wall, on the centerline, well I'm preaching to the choir here) Shift when wheels touch, then shift again when that funny little yellow light comes on (that second shift is for the Mopar only crowd), cross the line at 7700. Was I suppose to look at the tach before the finish line?
