M.T. ET Streets vs M.T. Drag radials #475007
09/21/09 08:53 AM
09/21/09 08:53 AM
Mentor,Oh.
fattire Offline OP
fattire  Offline OP
Mentor,Oh.
I have a '71 Challenger with 315/60/15 M.T. Drag radials on it,my problem is I'm blowing the tires of the first 60'. I had a 383 in it that pushed the car 12.25-12.30 with no tire spin at all. Now I have a 470 that is not real crazy it made 644hp/603tq. I did change the vert from a 3800 to a 4500 but the rest is the same. My best is 11.01 but my trap speed 122-124 so you see I'm leaving a lot on the table. So do you think the E.T. streets would be a better tire or should I spend the money on the suspension
Re: M.T. ET Streets vs M.T. Drag radials [Re: fattire] #475008
09/21/09 08:57 AM
09/21/09 08:57 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I had the 315/60/15 ET street Radials on my Indy EZ Headed 72 Challenger that was 3850lbs All motor and went 10.6 only time out! I had caltracs and went 1.55 60ft and 128.3mph still lean on the wideband...... whats your suspension like....
Mopar Performance
Re: M.T. ET Streets vs M.T. Drag radials [Re: moparniac] #475009
09/21/09 09:13 AM
09/21/09 09:13 AM
Mentor,Oh.
fattire Offline OP
fattire  Offline OP
Mentor,Oh.
I did have a 1.49 60' but the car was still spinning. I thought the tires would be ok too and seeing your performance I think I have a winter project. At 124mph trap I should be 10.85-10.95 just need it to hook.
Re: M.T. ET Streets vs M.T. Drag radials [Re: fattire] #475010
09/21/09 09:20 AM
09/21/09 09:20 AM
an8sec70cuda Offline
Keep the radials. I've been 1.32 sixty foot on the 295-65 M/T Radials. Nothing trick, just the basic Cal-Trac rear suspension.
What do you have for suspension? CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: M.T. ET Streets vs M.T. Drag radials [Re: fattire] #475011
09/21/09 09:20 AM
09/21/09 09:20 AM
Friend was running the m.t. street et's then switched to the m.t. drag radials and has had better 60's..i run the m.t. drag radials on my duster and with the 416 it 60's in the low 1.40's with nothing more then xhd leafs,pinion snubber,and 50/50 drag shocks..
Re: M.T. ET Streets vs M.T. Drag radials [Re: an8sec70cuda] #475012
09/21/09 09:30 AM
09/21/09 09:30 AM
Mentor,Oh.
fattire Offline OP
fattire  Offline OP
Mentor,Oh.
What do you have for suspension? CHIP [/quote
Well when I bought the car it had air shocks so I took them off and got some cal tracks [the car back-halved] but with out the air shocks it sits to low so I had to put some coil overs on to get the hieght back.
Re: M.T. ET Streets vs M.T. Drag radials [Re: fattire] #475013
09/21/09 09:32 AM
09/21/09 09:32 AM
Mentor,Oh.
fattire Offline OP
fattire  Offline OP
Mentor,Oh.
I messed that up
Re: M.T. ET Streets vs M.T. Drag radials [Re: fattire] #475014
09/21/09 10:24 AM
09/21/09 10:24 AM
So the car still has leaf springs? You need new ones if you have to adjust ride height w/ shocks. If you have Cal-Trac bars, call Calvert Racing and get a pair of their monoleaf springs and Rancho shocks. CHIP
CHIP
Re: M.T. ET Streets vs M.T. Drag radials [Re: an8sec70cuda] #475015
09/21/09 10:41 AM
09/21/09 10:41 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
Chip's right.. Get their leafs and be done with it.. I went 1.30 on radials and 1.28 with slicks.. But the radial was so much better to drive..
Re: M.T. ET Streets vs M.T. Drag radials [Re: 70dusterjohn] #475016
09/21/09 11:24 AM
09/21/09 11:24 AM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
Another vote to give the tires a chance to work. I just ordered my 3rd set of drag radials and really don't plan on running slicks again. I have been 1.29 60's footbraking and normally click of 1.32's in good weather all day with no problem.
Re: M.T. ET Streets vs M.T. Drag radials [Re: RonP] #475017
09/21/09 02:13 PM
09/21/09 02:13 PM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
I have to give my props to the drag radials especially if you have a heavy car. The side walls are alot stronger/stiffer.
I had a 1.49 60' with the 275 D/R's this weekend and my best on slicks was a 1.45 so these get my vote
Re: M.T. ET Streets vs M.T. Drag radials [Re: fattire] #475018
09/21/09 02:49 PM
09/21/09 02:49 PM
I have a pump gas street 3400 lbs. Duster that has gone 1:43 60. ft times on 315x60x15 M/T ET Street Radials at 10:34 and 128.6 MPH, no power adders It is a ladder bar car with coil overs and a track bar, I also have a set of 13:50x30x15 ET Street bias ply tires on the same size rims as the radials. The radials will run quicker and faster on a good track versus the bias ply tires, the bias ply tires will drive easier on a bad track and not spin at the top of first gear like the radials will on a bad track I have found that after driving the radails on the street, the first pass, no matter what kind of burn out I do , will spin bad, the second pass will hook a lot better no matter on the burn out procedures I do run between 17.5 lbs and 22 lbs in the radails and 9.5 to 11.0 lbs on the bias plys on ten inch wide rims. IHTHs BTW, if you run the air pressure to low in the radials they will not hook
Re: M.T. ET Streets vs M.T. Drag radials [Re: Cab_Burge] #475019
09/21/09 05:00 PM
09/21/09 05:00 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
How many passes are you getting out of the radials, we run them but after 3 or 4 months of going to the track they are done
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: M.T. ET Streets vs M.T. Drag radials [Re: 65signet] #475020
09/21/09 05:05 PM
09/21/09 05:05 PM
I only get 45 to 50 passes out of them before chords start showing. They go bald at about 25 passes. I do a fair amount of street driving on them too though. CHIP
CHIP
Re: M.T. ET Streets vs M.T. Drag radials [Re: 65signet] #475021
09/21/09 05:06 PM
09/21/09 05:06 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
The old cuda would last a season on a set. With lots of street miles. best 60' 1.36 with leafs. I wouldnt run another tire on that car....Phill
Re: M.T. ET Streets vs M.T. Drag radials [Re: an8sec70cuda] #475022
09/21/09 05:42 PM
09/21/09 05:42 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
We go to the track 2 or 3 times a month, and if you have a good day that will be like 8-10 passes in one day, at 300 for a set of tires i am looking for something that will last longer, when the tread is there they work great no complaint, when the tread goes there goes the 60 foot.
Re: M.T. ET Streets vs M.T. Drag radials [Re: 65signet] #475023
09/21/09 06:11 PM
09/21/09 06:11 PM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
The ET streets will last a ton longer.They will hook on a dirt road.I have run radials for a long time but I went back to ET streets.If you donot run a radial class get the ET streets.Why change the car to work on a radial when it will hook on the ETs?Its just a fad.I personally think the radials are a bad thing.On a fast car you can loop one in a heart beat.
Re: M.T. ET Streets vs M.T. Drag radials [Re: 8secDart] #475024
09/21/09 06:19 PM
09/21/09 06:19 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I only got 400 miles out of my ET streets.... Switched to the 315/60 Radials and the car just felt way better going down the track.....
Mopar Performance
Re: M.T. ET Streets vs M.T. Drag radials [Re: 8secDart] #475025
09/21/09 06:27 PM
09/21/09 06:27 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
how much air are you running?
Re: M.T. ET Streets vs M.T. Drag radials [Re: 65signet] #475026
09/22/09 07:34 AM
09/22/09 07:34 AM
When the tread goes there goes the 60 foot? Myself, and everyone else I know running them, have the opposite happen to us. The tires get better when the tread is gone. They hook great until the chords start showing, then I replace them. Still hook with the chords showing actually. This is the case with the M/T radials anyway. CHIP
CHIP
