Re: M.T. ET Streets vs M.T. Drag radials
[Re: fattire]
#475008
09/21/09 08:57 AM
09/21/09 08:57 AM
Posts: 6,295 U.S.
moparniac
U.S.
I had the 315/60/15 ET street Radials on my Indy EZ Headed 72 Challenger that was 3850lbs All motor and went 10.6 only time out! I had caltracs and went 1.55 60ft and 128.3mph still lean on the wideband...... whats your suspension like....
Mopar Performance
[Re: fattire]
#475010
09/21/09 09:20 AM
09/21/09 09:20 AM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
Keep the radials. I've been 1.32 sixty foot on the 295-65 M/T Radials. Nothing trick, just the basic Cal-Trac rear suspension. What do you have for suspension? CHIP
[Re: fattire]
#475011
09/21/09 09:20 AM
09/21/09 09:20 AM
Friend was running the m.t. street et's then switched to the m.t. drag radials and has had better 60's..i run the m.t. drag radials on my duster and with the 416 it 60's in the low 1.40's with nothing more then xhd leafs,pinion snubber,and 50/50 drag shocks..
[Re: an8sec70cuda]
#475012
09/21/09 09:30 AM
09/21/09 09:30 AM
Posts: 305 Mentor,Oh.
fattire
Mentor,Oh.
Keep the radials. I've been 1.32 sixty foot on the 295-65 M/T Radials. Nothing trick, just the basic Cal-Trac rear suspension. What do you have for suspension? CHIP [/quote Well when I bought the car it had air shocks so I took them off and got some cal tracks [the car back-halved] but with out the air shocks it sits to low so I had to put some coil overs on to get the hieght back.
[Re: fattire]
#475014
09/21/09 10:24 AM
09/21/09 10:24 AM
an8sec70cuda
So the car still has leaf springs? You need new ones if you have to adjust ride height w/ shocks. If you have Cal-Trac bars, call Calvert Racing and get a pair of their monoleaf springs and Rancho shocks. CHIP
[Re: RonP]
#475017
09/21/09 02:13 PM
09/21/09 02:13 PM
Posts: 2,117 Cleveland Ohio
10secGTX
Cleveland Ohio
I have to give my props to the drag radials especially if you have a heavy car. The side walls are alot stronger/stiffer. I had a 1.49 60' with the 275 D/R's this weekend and my best on slicks was a 1.45 so these get my vote
[Re: fattire]
#475018
09/21/09 02:49 PM
09/21/09 02:49 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
I have a pump gas street 3400 lbs. Duster that has gone 1:43 60. ft times on 315x60x15 M/T ET Street Radials at 10:34 and 128.6 MPH, no power adders It is a ladder bar car with coil overs and a track bar, I also have a set of 13:50x30x15 ET Street bias ply tires on the same size rims as the radials. The radials will run quicker and faster on a good track versus the bias ply tires, the bias ply tires will drive easier on a bad track and not spin at the top of first gear like the radials will on a bad track I have found that after driving the radails on the street, the first pass, no matter what kind of burn out I do , will spin bad, the second pass will hook a lot better no matter on the burn out procedures I do run between 17.5 lbs and 22 lbs in the radails and 9.5 to 11.0 lbs on the bias plys on ten inch wide rims. IHTHs BTW, if you run the air pressure to low in the radials they will not hook
[Re: 65signet]
#475020
09/21/09 05:05 PM
09/21/09 05:05 PM
an8sec70cuda
I only get 45 to 50 passes out of them before chords start showing. They go bald at about 25 passes. I do a fair amount of street driving on them too though. CHIP
[Re: 65signet]
#475026
09/22/09 07:34 AM
09/22/09 07:34 AM
an8sec70cuda
We go to the track 2 or 3 times a month, and if you have a good day that will be like 8-10 passes in one day, at 300 for a set of tires i am looking for something that will last longer, when the tread is there they work great no complaint, when the tread goes there goes the 60 foot.
When the tread goes there goes the 60 foot? Myself, and everyone else I know running them, have the opposite happen to us. The tires get better when the tread is gone. They hook great until the chords start showing, then I replace them. Still hook with the chords showing actually. This is the case with the M/T radials anyway. CHIP
