throttle cable problem? EDIT: PICS ADDED #471347
09/17/09 09:53 PM
09/17/09 09:53 PM
KY
juicedcuda Offline OP
KY
Posted a while ago about my stock e-body throttle cable being too short now that my motor is taller, etc. I was told to just order a longer one off the list in the tech pages. I got the longer one and it fits perfect but this cable has a lot less travel than the old one. The car cant get full throttle now. I am using the jegs billet 4500 mopar throttle bracket, so a lokar cable wont work. What should I do?
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Post deleted by Defbob [Re: juicedcuda] #471348
09/17/09 10:13 PM
09/17/09 10:13 PM
Re: throttle cable problem? #471349
09/17/09 10:20 PM
09/17/09 10:20 PM
KY
KY
TRIM THE CABLE SLEEVE IF IT'S HITTING THE END
When you say trim the cable sleeve, what exactly are you referring to? It seems all the ends are pressed/molded on.
Re: throttle cable problem? [Re: juicedcuda] #471350
09/17/09 10:59 PM
09/17/09 10:59 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
The black plastic, measure how much cable was showing on the old one and trim the new one to the same amount.
Re: throttle cable problem? [Re: rowin4] #471351
09/17/09 11:03 PM
09/17/09 11:03 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I have the same basic issue , I've tried about 15 things to make it go to WOT
I'm going to make linkage I think
it only goes about 3/4 the way maybe ..
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: throttle cable problem? [Re: bigdad] #471352
09/18/09 07:52 AM
09/18/09 07:52 AM
KY
KY
I only get like 1/4 travel. I don't see how trimming the black could help bc all the metal ends are pressed on.
Post deleted by Defbob [Re: juicedcuda] #471353
09/18/09 07:58 AM
09/18/09 07:58 AM
Re: throttle cable problem? #471354
09/18/09 08:20 AM
09/18/09 08:20 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I used a /6 cable from a 73 Dart we scrapped on my 65.It has M1 and Dominator.Had to rework the pedal end as they are different and as Fred said I trimmed the outer shell a bit.All you have to do is cut a bit off where the cable itself pulls over the part thats in the clamp.It dosent caome apart.Then after its trimmed I just cut that piece off with some good diag pliers.Kind of hard to explain but easy to do.
Rocky
Chrysler Firepower
Re: throttle cable problem? [Re: therocks] #471355
09/18/09 02:24 PM
09/18/09 02:24 PM
KY
KY
updated with pictures.
Post deleted by Defbob [Re: juicedcuda] #471356
09/18/09 02:45 PM
09/18/09 02:45 PM
Re: throttle cable problem? #471357
09/18/09 02:48 PM
09/18/09 02:48 PM
KY
KY
Too small to see but it looks like you can trim the sleeve to allow more travel of the section that moves
sorry, all I had available was my phone.
Post deleted by Defbob [Re: juicedcuda] #471358
09/18/09 02:53 PM
09/18/09 02:53 PM
Re: throttle cable problem? #471359
09/18/09 03:01 PM
09/18/09 03:01 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
You can extend the travel of the pedal if it's a small difference.
You can shorten the outer sheath of the cable to allow more throw.
You can move the point where the cable attaches to the carb closer to the center to shorten the needed throw. See poor drawing...
Re: throttle cable problem? #471360
09/18/09 03:04 PM
09/18/09 03:04 PM
Nova Scotia Canada
Blue71 Offline
Blue71  Offline
Nova Scotia Canada
Hi
Had the same problem with a new cable.Had to do what is being said.I used a small pipe cutter and cut about 1" off the metal sleeve then carefully ground the side of the cut piece enough to pass the cable through.
Ken
Re: throttle cable problem? EDIT: PICS ADDED [Re: juicedcuda] #471361
09/18/09 03:35 PM
09/18/09 03:35 PM
AndyF Offline
AndyF  Offline
The amount of travel depends on which hole in the carb linkage that the cable goes to. The closer to the pivot shaft the less the cable travel has to be. (but the higher the effort) Also, you need to make sure that the travel at the carb is the same as full pedal travel, otherwise you'll either not have enough travel or the carb will bottom before the pedal does.
Re: throttle cable problem? EDIT: PICS ADDED [Re: AndyF] #471362
09/18/09 05:08 PM
09/18/09 05:08 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
I use similar cable with the bracket AndyF makes. I have used it on an M1 4500/ dominator and then on an M1 4150/ 950. I was able to reuse everything over when I swapped intakes with a very small adjustment. I would reccomend that bracket to anybody. I painted mine. so easy and priced right.
here is a pic under the air cleaner
maybe this isnt tall enough to rear your intake/ carb combo?
Re: throttle cable problem? EDIT: PICS ADDED [Re: Joshs68] #471363
09/18/09 05:08 PM
09/18/09 05:08 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
and without
Re: throttle cable problem? EDIT: PICS ADDED [Re: AndyF] #471364
09/18/09 06:34 PM
09/18/09 06:34 PM
KY
KY
I did the pipe cutter trick and used a dremel to slice the rest of the metal sheath off. I now can get full throttle. Is there a problem if the carb bottoms before the pedal does?
Re: throttle cable problem? EDIT: PICS ADDED [Re: juicedcuda] #471365
09/18/09 07:21 PM
09/18/09 07:21 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Yes, eventually it will ruin the throttle shaft
Put stopp under it
Post deleted by Defbob [Re: bigdad] #471366
09/18/09 08:32 PM
09/18/09 08:32 PM
