throttle cable problem? EDIT: PICS ADDED
#471347
09/17/09 09:53 PM
09/17/09 09:53 PM
Posts: 761 KY
juicedcuda
KY
1970 Plymouth 'Cuda
1970 Plum Crazy "Gold Duster"
1973 Gold Duster
Post deleted by Defbob
[Re: juicedcuda]
#471348
09/17/09 10:13 PM
09/17/09 10:13 PM
Re: throttle cable problem?
[Re: rowin4]
#471351
09/17/09 11:03 PM
09/17/09 11:03 PM
Posts: 34,884 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I have the same basic issue , I've tried about 15 things to make it go to WOT
I'm going to make linkage I think
it only goes about 3/4 the way maybe ..
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: bigdad]
#471352
09/18/09 07:52 AM
09/18/09 07:52 AM
Posts: 761 KY
juicedcuda
KY
I only get like 1/4 travel. I don't see how trimming the black could help bc all the metal ends are pressed on.
1970 Plymouth 'Cuda
1973 Gold Duster
[Re: juicedcuda]
#471353
09/18/09 07:58 AM
09/18/09 07:58 AM
#471354
09/18/09 08:20 AM
09/18/09 08:20 AM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
I used a /6 cable from a 73 Dart we scrapped on my 65.It has M1 and Dominator.Had to rework the pedal end as they are different and as Fred said I trimmed the outer shell a bit.All you have to do is cut a bit off where the cable itself pulls over the part thats in the clamp.It dosent caome apart.Then after its trimmed I just cut that piece off with some good diag pliers.Kind of hard to explain but easy to do. Rocky
Chrysler Firepower
[Re: juicedcuda]
#471356
09/18/09 02:45 PM
09/18/09 02:45 PM
[Re: juicedcuda]
#471358
09/18/09 02:53 PM
09/18/09 02:53 PM
Re: throttle cable problem? EDIT: PICS ADDED
[Re: juicedcuda]
#471361
09/18/09 03:35 PM
09/18/09 03:35 PM
Posts: 31,026 Oregon
AndyF
The amount of travel depends on which hole in the carb linkage that the cable goes to. The closer to the pivot shaft the less the cable travel has to be. (but the higher the effort) Also, you need to make sure that the travel at the carb is the same as full pedal travel, otherwise you'll either not have enough travel or the carb will bottom before the pedal does.
[Re: bigdad]
#471366
09/18/09 08:32 PM
09/18/09 08:32 PM
