Anybody installed the Milidon gear drive..smallblock? #470889
09/17/09 12:26 PM
09/17/09 12:26 PM
Portage,michigan
B3422W5 Online content OP
B3422W5  Online Content OP
Portage,michigan
If so, how did it go and how happy are you with the gear drive?
tia
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Anybody installed the Milidon gear drive..smallblock? [Re: B3422W5] #470890
09/17/09 12:35 PM
09/17/09 12:35 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
my 422 had one and it worked great!
Re: Anybody installed the Milidon gear drive..smallbloc [Re: MegaDart] #470891
09/17/09 12:53 PM
09/17/09 12:53 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
How much noise is associated with the gear drive?
Re: Anybody installed the Milidon gear drive..smallbloc [Re: Jeepmon] #470892
09/17/09 01:08 PM
09/17/09 01:08 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
I used one years ago. It was very quite with only a hint of noise. Liked the ability of holding the timing very stable due to no chain slop. The only thing I didn't like was the way the idler gear was fastened. The bolts eventually came loose but it never fell off or did any damage. Only found it after tear down and inspection. I would still use one today but would pay closer attention to loctiting the fasteners into place.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Anybody installed the Milidon gear drive..smallblock? [Re: B3422W5] #470893
09/17/09 01:11 PM
09/17/09 01:11 PM
Great White North
alkyfish69 Offline
alkyfish69  Offline
Great White North
One of my best purchases, great quality,not noisy and degreeing the cam is easy.
