Anybody installed the Milidon gear drive..smallblock?
#470889
09/17/09 12:26 PM
09/17/09 12:26 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
If so, how did it go and how happy are you with the gear drive? tia
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: Anybody installed the Milidon gear drive..smallbloc
[Re: Jeepmon]
#470892
09/17/09 01:08 PM
09/17/09 01:08 PM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
I used one years ago. It was very quite with only a hint of noise. Liked the ability of holding the timing very stable due to no chain slop. The only thing I didn't like was the way the idler gear was fastened. The bolts eventually came loose but it never fell off or did any damage. Only found it after tear down and inspection. I would still use one today but would pay closer attention to loctiting the fasteners into place.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Anybody installed the Milidon gear drive..smallblock?
[Re: B3422W5]
#470893
09/17/09 01:11 PM
09/17/09 01:11 PM
Posts: 40 Great White North
alkyfish69
Great White North
If so, how did it go and how happy are you with the gear drive? One of my best purchases, great quality,not noisy and degreeing the cam is easy.
