5/8" studs
#467283
09/13/09 09:06 PM
09/13/09 09:06 PM
Posts: 761 KY
juicedcuda
KY
When are 5/8" studs necessary?
1970 Plymouth 'Cuda
1970 Plum Crazy "Gold Duster"
1973 Gold Duster
Re: 5/8" studs
[Re: SuperStocker]
#467285
09/13/09 09:29 PM
09/13/09 09:29 PM
Posts: 1,613 Deerfield, Ohio
70dusterjohn
Deerfield, Ohio
Whenever you want to rid yourself of worrying about breaking studs...
and if your running a shank lug nut, it does away with that.. Thats where they break is at the end of the shank..
Re: 5/8" studs
[Re: bigtimeauto]
#467287
09/14/09 11:23 AM
09/14/09 11:23 AM
Posts: 761 KY
juicedcuda
KY
So besides buying the lug nuts and oredering the 5/8" stud option from moser, is there anything else that needs to be done. I am using rear drums and weld prostars.
1970 Plymouth 'Cuda
1973 Gold Duster
Re: 5/8" studs
[Re: juicedcuda]
#467288
09/14/09 11:28 AM
09/14/09 11:28 AM
Quicktree
yea you have to make sure the 5/8 studs will go through the holes.
Re: 5/8" studs
[Re: bigtimeauto]
#467291
09/14/09 03:03 PM
09/14/09 03:03 PM
Posts: 761 KY
juicedcuda
KY
Will the drums have to be drilled and what are the spacers for?
1970 Plymouth 'Cuda
1973 Gold Duster
Re: 5/8" studs
[Re: juicedcuda]
#467292
09/14/09 03:44 PM
09/14/09 03:44 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
Yes the drums will need to be drilled. the spacers are for taking up the space between the wheel and the nut. The studs have a shoulder on them.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: 5/8" studs
[Re: John_Kunkel]
#467294
09/14/09 03:54 PM
09/14/09 03:54 PM
bigtimeauto
Trophy Winner
Trophy Winner
the spacers are for the lenght of the stud. The stud is 5/8ths bolt with 11/16ths shoulder measurment. This picture should clear it up
