5/8" studs #467283
09/13/09 09:06 PM
09/13/09 09:06 PM
KY
juicedcuda Offline OP
KY
When are 5/8" studs necessary?
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: 5/8" studs [Re: juicedcuda] #467284
09/13/09 09:26 PM
09/13/09 09:26 PM
Vacherie, Louisiana
SuperStocker Offline
super gas
super gas
Vacherie, Louisiana
Whenever you want to rid yourself of worrying about breaking studs...
Re: 5/8" studs [Re: SuperStocker] #467285
09/13/09 09:29 PM
09/13/09 09:29 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
and if your running a shank lug nut, it does away with that.. Thats where they break is at the end of the shank..
Re: 5/8" studs [Re: 70dusterjohn] #467286
09/13/09 09:38 PM
09/13/09 09:38 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
and when you don't want to lift your wheel and tire to get the shanked lug nut on.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: 5/8" studs [Re: bigtimeauto] #467287
09/14/09 11:23 AM
09/14/09 11:23 AM
KY
KY
So besides buying the lug nuts and oredering the 5/8" stud option from moser, is there anything else that needs to be done. I am using rear drums and weld prostars.
Re: 5/8" studs [Re: juicedcuda] #467288
09/14/09 11:28 AM
09/14/09 11:28 AM
Q
Quicktree Offline
Quicktree  Offline
Q
yea you have to make sure the 5/8 studs will go through the holes.
Re: 5/8" studs [Re: juicedcuda] #467289
09/14/09 11:30 AM
09/14/09 11:30 AM
Deerfield, Ohio
Deerfield, Ohio
No, when you buy the studs, you will get the lug nuts, and spacers.. that is all you need. You may need to run a drill through the holes in the wheel to get them on the studs.. Just clean them up a bit..
Re: 5/8" studs [Re: 70dusterjohn] #467290
09/14/09 12:10 PM
09/14/09 12:10 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
one thing i forgot, you will never be able to put a stock wheel on it unless you drill them.
Re: 5/8" studs [Re: bigtimeauto] #467291
09/14/09 03:03 PM
09/14/09 03:03 PM
KY
KY
Will the drums have to be drilled and what are the spacers for?
Re: 5/8" studs [Re: juicedcuda] #467292
09/14/09 03:44 PM
09/14/09 03:44 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Yes the drums will need to be drilled. the spacers are for taking up the space between the wheel and the nut. The studs have a shoulder on them.
Re: 5/8" studs [Re: juicedcuda] #467293
09/14/09 03:50 PM
09/14/09 03:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Or you can go with 11/16" Super Studs and don't have to fool with the spacers.
Re: 5/8" studs [Re: John_Kunkel] #467294
09/14/09 03:54 PM
09/14/09 03:54 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
the spacers are for the lenght of the stud.
The stud is 5/8ths bolt with 11/16ths shoulder measurment.
This picture should clear it up
