'71 B Body Vapor Separator #463907
09/09/09 12:15 PM
09/09/09 12:15 PM
New Hampshire
W
whitemtnelf Offline OP
W
New Hampshire
The vapor separator that's behind the left rear fender is totally shot. I'm not having much luck locating one at a reasonable price. Has anyone come up with an alternate solution?
Re: '71 B Body Vapor Separator [Re: whitemtnelf] #463908
09/09/09 01:23 PM
09/09/09 01:23 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Are you talking about the Charcoal-Canister?
I still have mine in the garage somewhere, but it hasn't been IN the car/hooked-up for decades.
I still like to hang on to ALL my "Original-Equipment" in case I ever wanted to set everything back to factory-correct.
Re: '71 B Body Vapor Separator [Re: D_C] #463909
09/09/09 01:25 PM
09/09/09 01:25 PM
New Hampshire
W
W
New Hampshire
No. There's a metal box with 4 lines coming out of it that is mounted behind the left rear wheel. The shield that protected it was gone and there wasn't much left of the separator
Re: '71 B Body Vapor Separator [Re: D_C] #463910
09/09/09 01:26 PM
09/09/09 01:26 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
The vapor liquid seperator tank thats in the back of the left rear wheel well on 71's and early 72's.
The one in your pic is a late 72 and 73 style.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: '71 B Body Vapor Separator [Re: moparmarks] #463911
09/09/09 01:30 PM
09/09/09 01:30 PM
New Hampshire
W
W
New Hampshire
That's what I've been trying to find. Any ideas for a work around in case I can't find one in good shape?
Re: '71 B Body Vapor Separator [Re: whitemtnelf] #463912
09/09/09 04:20 PM
09/09/09 04:20 PM
IL
furious70 Offline
furious70  Offline
IL
interesting, my 70 Fury has that tank inside the main fuel tank and has the separator in the trunk (just a tall vent with the 4 lines going into it).
Are you trying to restore it correctly or just have it run? You don't need it to run, you can just plug the extra ports for the separator in the main tank and run a vented cap like the pre-emission cars do, and not hook up the hose to the breather and carb.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: '71 B Body Vapor Separator [Re: furious70] #463913
09/09/09 04:35 PM
09/09/09 04:35 PM
New Hampshire
W
W
New Hampshire
I'm building this car for fun so I'm not concerned with it being factory correct. should I use the line that goes to the charcoal canister for the vent?
Re: '71 B Body Vapor Separator [Re: whitemtnelf] #463914
09/09/09 04:38 PM
09/09/09 04:38 PM
IL
furious70 Offline
furious70  Offline
IL
I think the easiest thing to do is plug all the vent ports in the tank and use a 1968 fuel cap for a RR or Coronet. You may need 1 vent with that as well, someone else will chime in. As long as the vent is higher than the tank, I think the line you're talking about would be fine for the vent, just bend the end over so no junk can get in.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: '71 B Body Vapor Separator [Re: whitemtnelf] #463915
09/09/09 05:05 PM
09/09/09 05:05 PM
D_C Offline
D_C  Offline
You could check Junkyards, but may not find one in much better condition, but then again, worth a shot.
You might be able to substitute one from another vehicle or something more modern. I have a Plastic Vapor-Separator for the fuel-tank on my '79 CJ-5 Jeep.
I'm guessing autoparts stores and/or junkyards would be potential sources.
In any event, I wouldn't count on the Charcoal-Canister doing the job. Also, seems like there should be a better solution than going to an "open" or un-vented system like they had in '68. It could work, but there might be other problems.
Re: '71 B Body Vapor Separator [Re: D_C] #463916
09/09/09 05:23 PM
09/09/09 05:23 PM
IL
furious70 Offline
furious70  Offline
IL
The only 'problem' is vapor out to atmosphere, which if you're very eco-friendly you might not want to do, but I'm in the camp that it's a non-issue on a collector car.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: '71 B Body Vapor Separator [Re: furious70] #463917
09/09/09 06:15 PM
09/09/09 06:15 PM
Sobieski Wi
bee1971 Online work
bee1971  Online Work
Sobieski Wi
AMD sells the shields that the vapor seperator attach to - I have seen them , they look nice
The actual vapor seperator itself i have seen on Ebay and like mentioned junkyards and i will have to find or remember the guy that sells alot of 71/72 B body Parts
Click on link
http://www.autometaldirect.com/ListItems/MainCategory/Quarter.aspx
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: '71 B Body Vapor Separator [Re: furious70] #463918
09/09/09 06:38 PM
09/09/09 06:38 PM
Tennessee
WyleECoyote Offline
WyleECoyote  Offline
Tennessee
Plug all vents on the tank except one and connect that to the vent line that goes to the carb - OR -Plug all four vents and use a sending unit with a vent return and connect the vent from the carb to the sending unit.
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: '71 B Body Vapor Separator [Re: WyleECoyote] #463919
09/10/09 09:35 AM
09/10/09 09:35 AM
New Hampshire
W
W
New Hampshire
I did see a rusted separator on eBay but he wanted $100 - no way. I'll go with the vent line to the carb.
Thanks for all of the input.
Re: '71 B Body Vapor Separator [Re: whitemtnelf] #463920
09/10/09 11:02 AM
09/10/09 11:02 AM
moparmarks Offline
moparmarks  Offline
I sent you a PM. Did you get it?
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: '71 B Body Vapor Separator [Re: whitemtnelf] #463921
11/15/09 04:58 PM
11/15/09 04:58 PM
indiana
generallee6901 Offline
indiana
I have one i will sell alot cheaper than the ones on ebay.If you are interested pm me or email me at generallee6901@verizon.net and i will send some pics and a price.Not looking to get rich just trying to get rid of all my extra parts from my 71.
Re: '71 B Body Vapor Separator [Re: generallee6901] #463922
11/15/09 08:00 PM
11/15/09 08:00 PM
moparmarks Offline
moparmarks  Offline
I have one for 40.00 but I guess he didn't want it.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
