Re: '71 B Body Vapor Separator
[Re: whitemtnelf]
#463908
09/09/09 01:23 PM
09/09/09 01:23 PM
Posts: 1,373 Rancho Cucamonga, CA
D_C
Are you talking about the Charcoal-Canister? I still have mine in the garage somewhere, but it hasn't been IN the car/hooked-up for decades. I still like to hang on to ALL my "Original-Equipment" in case I ever wanted to set everything back to factory-correct.
[Re: D_C]
#463910
09/09/09 01:26 PM
09/09/09 01:26 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
The vapor liquid seperator tank thats in the back of the left rear wheel well on 71's and early 72's. The one in your pic is a late 72 and 73 style.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: whitemtnelf]
#463912
09/09/09 04:20 PM
09/09/09 04:20 PM
Posts: 2,255 IL
furious70
IL
interesting, my 70 Fury has that tank inside the main fuel tank and has the separator in the trunk (just a tall vent with the 4 lines going into it).
Are you trying to restore it correctly or just have it run? You don't need it to run, you can just plug the extra ports for the separator in the main tank and run a vented cap like the pre-emission cars do, and not hook up the hose to the breather and carb.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: whitemtnelf]
#463914
09/09/09 04:38 PM
09/09/09 04:38 PM
Posts: 2,255 IL
furious70
IL
I think the easiest thing to do is plug all the vent ports in the tank and use a 1968 fuel cap for a RR or Coronet. You may need 1 vent with that as well, someone else will chime in. As long as the vent is higher than the tank, I think the line you're talking about would be fine for the vent, just bend the end over so no junk can get in.
[Re: whitemtnelf]
#463915
09/09/09 05:05 PM
09/09/09 05:05 PM
D_C
You could check Junkyards, but may not find one in much better condition, but then again, worth a shot.
You might be able to substitute one from another vehicle or something more modern. I have a Plastic Vapor-Separator for the fuel-tank on my '79 CJ-5 Jeep.
I'm guessing autoparts stores and/or junkyards would be potential sources.
In any event, I wouldn't count on the Charcoal-Canister doing the job. Also, seems like there should be a better solution than going to an "open" or un-vented system like they had in '68. It could work, but there might be other problems.
[Re: D_C]
#463916
09/09/09 05:23 PM
09/09/09 05:23 PM
Posts: 2,255 IL
furious70
IL
The only 'problem' is vapor out to atmosphere, which if you're very eco-friendly you might not want to do, but I'm in the camp that it's a non-issue on a collector car.
[Re: furious70]
#463917
09/09/09 06:15 PM
09/09/09 06:15 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
AMD sells the shields that the vapor seperator attach to - I have seen them , they look nice The actual vapor seperator itself i have seen on Ebay and like mentioned junkyards and i will have to find or remember the guy that sells alot of 71/72 B body Parts Click on link http://www.autometaldirect.com/ListItems/MainCategory/Quarter.aspx
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: whitemtnelf]
#463921
11/15/09 04:58 PM
11/15/09 04:58 PM
Posts: 465 indiana
generallee6901
indiana
I have one i will sell alot cheaper than the ones on ebay.If you are interested pm me or email me at generallee6901@verizon.net and i will send some pics and a price.Not looking to get rich just trying to get rid of all my extra parts from my 71.
