Trans guys got a question #461197
09/06/09 09:34 PM
09/06/09 09:34 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
If you got a hole in the front drum.I know it there for using a trans brake. To bleed off pressure. and I know front clutchs are on in reverse and high gear. If I do not use a trans brake valve body.will there be any problems ?
Re: Trans guys got a question [Re: VernMotor] #461198
09/06/09 09:48 PM
09/06/09 09:48 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I've never noticed an issue when I put it into reverse or when I go into third.
Re: Trans guys got a question [Re: WILD BILL] #461199
09/07/09 01:46 AM
09/07/09 01:46 AM
Johnstown
69dart Offline
69dart  Offline
Johnstown
It should be good thats one of the mods out of the CRT book.
Re: Trans guys got a question [Re: 69dart] #461200
09/07/09 06:17 AM
09/07/09 06:17 AM
CT
turbocolt2.4L Offline
CT
youll be good it shoulnt mater if you run a small bleed hole with a manual vb the bleed hole is there to aid in the brake release.
Re: Trans guys got a question [Re: turbocolt2.4L] #461201
09/07/09 07:20 AM
09/07/09 07:20 AM
TN
65racer Offline
2009 IHRA World Champion
65racer  Offline
TN
Should not be a problem, I drilled one in mine when I did my last tranny for my car, as I put the brake back in it, but have never used it, and it seems fine. Would not hesitate to use a drilled drum in a rebuild.
Re: Trans guys got a question [Re: 65racer] #461202
09/07/09 08:17 AM
09/07/09 08:17 AM
NC
440Jim Offline
440Jim  Offline
NC
I agree. A properly drilled (small) hole for a transbrake will be fine with an aftermarket manual valve body.
Re: Trans guys got a question [Re: 440Jim] #461203
09/07/09 09:36 AM
09/07/09 09:36 AM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
My thought would be as long as its in a manual VB with full line pressure. A VB set up with the throttle linkage and variable line pressure may have issues.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Trans guys got a question [Re: turbobitt] #461204
09/07/09 09:50 AM
09/07/09 09:50 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Just with a hole in it you have to relocate the vent from front pump housing!
Re: Trans guys got a question [Re: Dodgem] #461205
09/07/09 09:54 AM
09/07/09 09:54 AM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
vent is moved.. Thanks guy just thought I ask.
Re: Trans guys got a question [Re: VernMotor] #461206
09/07/09 10:04 AM
09/07/09 10:04 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If the trans is apart and it's not needed you could seal the hole , tapped for a small set screw installed with RED loctite would do the trick .
