Re: Trans guys got a question
[Re: turbocolt2.4L]
#461201
09/07/09 07:20 AM
09/07/09 07:20 AM
Posts: 1,235 TN
65racer
2009 IHRA World Champion
TN
Should not be a problem, I drilled one in mine when I did my last tranny for my car, as I put the brake back in it, but have never used it, and it seems fine. Would not hesitate to use a drilled drum in a rebuild. Dave
[Re: 440Jim]
#461203
09/07/09 09:36 AM
09/07/09 09:36 AM
Posts: 759 Southington Ct.
turbobitt
Southington Ct.
My thought would be as long as its in a manual VB with full line pressure. A VB set up with the throttle linkage and variable line pressure may have issues.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
