All Indy 440-25 crossram users.......
#461084
09/06/09 09:17 PM
09/06/09 09:17 PM
post up your jetting metering jets, metering rods, metering springs, accelerator pump home placement. and what jets you run. also post your altitude where you run at, which is very important. after everyone puts up your jets sizes, i will share a secret which will get you .15 faster ET with your combo. a few select guys on here may know of the secret but ill share it with you anyway.
Re: All Indy 440-25 crossram users.......
#461085
09/06/09 09:20 PM
09/06/09 09:20 PM
also forgot to add your cubic inch displacement.
#461089
09/07/09 02:38 PM
09/07/09 02:38 PM
does it matter which carbs are being used?
#461090
09/07/09 04:06 PM
09/07/09 04:06 PM
works with both carter and edelbrocks, i just switched out a set of 750 carters to edelbrock 800's leaned them out a tad and went with a little richer metering rod for this weekend. i feel it was too rich at launch only getting a 1.41 60 foot. and it slowed down 3 mph and .1 with 3 jet sizes richer. i definitely thought the .116 jets would have woken the car up but no, even with half way decent air, it slowed down so ill be at .113 square for this weekend.
#461091
09/07/09 04:33 PM
09/07/09 04:33 PM
We are running .119sq. and the lightest springs and the large squirters. My 800's are highly modified, no air horns...They are worth .3 over stock 750's
#461093
09/07/09 09:01 PM
09/07/09 09:01 PM
Posts: 6,350 Aurora, Oh.
max_maniac
Aurora, Oh.
Ok now I'm confused you start this post letting us know that you have the secret to tune these carbs for a .15 better et and then you say you adjusted "yours" and you lose et so is this a trick post
[Re: dvw]
#461094
09/07/09 09:09 PM
09/07/09 09:09 PM
They are a pair of Damon Kuhn 800's that have been massaged in the venturi areas, had mods done to the weights and to the fuel bowls along with several other internal mods. Pm me Doug if you want all the details....poppaj
[Re: max_maniac]
#461095
09/07/09 09:24 PM
09/07/09 09:24 PM
Russ, no this is not a trick post, i already found the .15 increase, i was just looking to see if i could squeeze another .0500 out of the combo, i jetted it up some more figuring the air was a little better but it didnt work, so im going to try a jet configuration. im looking for some more jet combos from a few more 440-25 members then ill all let you in on the easiest cheapest way to pick up .15
#461096
09/08/09 03:28 PM
09/08/09 03:28 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
We had 113pri-107 sec. went [Email]9.05@149.66[/Email] at 2800da.@3620 lbs.
JAKES AUTOMOTIVE
[Re: JAKE68]
#461097
09/08/09 03:35 PM
09/08/09 03:35 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
my interest is peaked but i have never ran the combo
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#461098
09/10/09 08:53 AM
09/10/09 08:53 AM
Maybe you're talking about closing the rear throttle blades about 15*????.............
#461100
09/11/09 06:57 PM
09/11/09 06:57 PM
Posts: 1,400 Wi.
old_racer
Wi.
we're still waiting for the easiest cheapest way to pick up .15!!!! thanks
[Re: old_racer]
#461101
09/11/09 09:34 PM
09/11/09 09:34 PM
heres the pieces to put inside the indy crossram,they are made of epoxy sleeved with longer bolts. they are going on my 500 ci motor in my 63 plymouth, this should get me right where i wanna be.
#461102
09/11/09 09:40 PM
09/11/09 09:40 PM
max_maniac
Aurora, Oh.
And here all along I thought you were going to tell us all to join Jenny Craig I know I could lose a few lbs but not enough to gain .15 so, are you going to do a back to back test on these at the track to verify the .15 gain?
Russ
[Re: max_maniac]
#461103
09/11/09 09:43 PM
09/11/09 09:43 PM
Russ
already have Russ on the 65 dodge, its a full .15 i had to get the other set before i posted, they've just made another run of them.
[Re: biff426]
#461105
09/11/09 11:05 PM
09/11/09 11:05 PM
sixpackgut
Charleston
in the new mopar muscle, those plenum fillers picked up hardly anything on the dyno but if you say it did pick up i believe it
[Re: Kevins493]
#461109
09/11/09 11:22 PM
09/11/09 11:22 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
It may not have made more peak hp, but if there was more area under the curve (made more power at lower rpm's for example) it would get the car moving faster.
EXACTLY,,,DING,,,,,,,DING,,,,,,,DING When SSR spoke to Ken at Carlisle,he said that it did not really make more HP,but the torque picked up faster in the lower RPM range.
[Re: hemi-itis]
#461110
09/12/09 07:50 AM
09/12/09 07:50 AM
the biggest problem with the intake is the puddling of fuel, the fuel wasnt getting down in the correct path properly, this is part of vthe backfire problem as well as it is a very large plenum. these will shorten the fuel path,creating better low end and better et. indy did there homework on these or someone played around with the intake and gave the info. to indy. 5 years ago i tried something similar but not this large of a diameter inserts. it helped some but not .15 i got about .030 better.
#461111
09/12/09 12:10 PM
09/12/09 12:10 PM
Posts: 3,504 DFW
mr_340
DFW
I hope Indy is going to change the casting to reflect the new configuration. Do you have any pictures of the inserts installed?
Floyd Lippencott IV
[Re: hemi-itis]
#461112
09/14/09 10:12 PM
09/14/09 10:12 PM
I can't bite my lip any longer......
You have NO ACTUAL proof that it's worth power (MPH).......Mopar Muscle AND Indy BOTH say it's not worth anything, but you say it's worth a tenth and a half on a low 9 second car??? That's a fairly huge power gain........What was the trap speed, before and after??? and was it on the same day???
Maybe the converter in your car isn't optimized for the way the intake was before????? How many converters have you tried in your car? Contrary to what a LOT of people think, torque doesn't mean very much in a drag car because it can be made up for with gearing in the rearend, transmission, and in the converter (torque multiplication)........
Yeah, Stevie Wonder can see that.........just look at all the turns the air has to make just to get to the runners..........
Show same day, back to back dyno tests......then show back to back same day ET slips, or this is all a waste of time....... Saying "easiest cheapest way to pick up .15" is a pretty broad statement to make without any dyno proof that it actually makes more HP on a LOT of different combos.......
#461113
09/15/09 03:26 PM
09/15/09 03:26 PM
hmmm... something is a little fishy here
Last year you say you pick up all of this power solely on jetting and messing with the carbs... now its these things?
Didnt you rip us last year saying the reason there is puddling in our intake is because our jetting was off?
the way you run your mouth you would have told us about these things last year if they actually worked.... lets see some pictures chris, and like as said previously lets see some back to back tests.
dont get on here saying you have a proven .15 if you have never even ran the things... this post is bogus. end of sorry.
Casey
#461114
09/15/09 04:07 PM
09/15/09 04:07 PM
Posts: 705 Michigan
Hemiroid
[Re: Hemiroid]
#461115
09/15/09 04:10 PM
09/15/09 04:10 PM
max_maniac
Aurora, Oh.
POPCORN! GET YOUR POPCORN!!
I got mine ----------------
#461116
09/15/09 09:50 PM
09/15/09 09:50 PM
Casey
Einstein your ignorance is only preceded by your incompedence. these inserts werent available last year, i did pick up with just jetting and some carb mods last year. this year its with these installed, heres your installed pictures as requested. just remember i know how to make power. when you get out of the 9.70's let me know. by that time ill be 8.40's good luck!
#461117
09/15/09 09:50 PM
09/15/09 09:50 PM
another
#461118
09/15/09 09:53 PM
09/15/09 09:53 PM
last one for the nasayers.
[Re: Dragula]
#461121
09/15/09 10:22 PM
09/15/09 10:22 PM
In the old days, they would just machine the tops of the runners back further to have straighter/shorter air flow path somewhat. Have you thought about doing that? Are you going to touch the runners or raduis any of the inlets at all? Just curious.
I like the looks of those intakes, but after running a rat roaster for years with two 750 eddy carbs I modifed, I really don't have the want to go back that way again. I do give you a lot of credit though for making it work that well. I know from running mine that the metering rods and other tricks were closely guarded secrets. I asked more than a few people that had them running well, but always recieved very little info. I learned a few things that made my run what it did, but even the new single dommy intakes and carbs out run them.
Randy, i understand the rat roaster like the str14 were of a similar design, which IMO was not a good design. i heavily modified a str-14 which i got running pretty good but nothing like this 440-25. these intakes really work, making 80 hp over a stock oe max wedge crossram and 100+ over the STR-14 if i had a choice i would run a 440-3X and be done with it but NSS rules state no single 4-bbls allowed. also i like the challenge and fun to get these 2-4bbls to run and work with this 440-25 intake.
[Re: sixpakdodge]
#461122
09/15/09 10:25 PM
09/15/09 10:25 PM
Chris, for mine own curiosity, do you have a pic of the intake without those installed?
steve, no pictures without the inserts but you can get the idea ,the corners are fully blocked off with a sharp angle giving the fuel a straight run into the runners. i should have taken a picture with and without but....
[Re: B G Racing]
#461124
09/16/09 09:41 PM
09/16/09 09:41 PM
It would seem to me as well that fuel would gather in behind those things and cause additional problems. At the very least they would need to be epoxied in place for a good seal. But if they were worth anything I would think Indy would change the design of their intake By the way, we chose to run in the 9.70 range, there is plenty more left past the throttle stop. poppaj
#461126
09/17/09 02:22 AM
09/17/09 02:22 AM
Casey
hmmm once again your stories dont line up. Having trouble keeping your lies straight I see... let me help you out.
you claim to go 9.22 last year with just jetting correct?... so that means with this proven .15 this year you have been 9.07!!!!!! jeepers thats fast. Again with your loud mouth you would have been all over the internet saying how fast you went if you really went that fast.
funny thing is... tho, you havent even ran the dodge this year..... your scared of it remember? or ashamed... one of the two. so let me ask you this how is it possible to get a new best with a car that has not been ran? You got the products just this year right?? hmmm.. a little fishy to me fishboy, but im sure you can pull out some lie to cover your butt on this one.
once again your post is BOGUS.
a proven .15 eh? haha the only way your ever gonna pick up .15 is if you stop letting hemi-itis ride shotgun every pass
I wouldnt waste my money on these things. They have been PROVEN to make no more horse power on the dyno. thats all I need to hear. Thanks Casey
[Re: jake4cars]
#461128
09/17/09 08:34 AM
09/17/09 08:34 AM
hemi-itis
You guys need to get together and resolve all of this he said this, he said that stuff, you both have awesome 65's, now, if you can't play well together it will be separate sand boxes for the rest of the year and no cookies at break time.
Joey
C"mon Joey,I wanna play,I wana play Casey,If I,m not shotgun,,,,,,It would be a full 2 tenths .Now cannI has a coooooooooookie peeeeeeeez
[Re: jake4cars]
#461130
09/17/09 08:39 AM
09/17/09 08:39 AM
JAKE68
Shelby mi.
We have a set of them to try on lens car. We will do some testing with them after we get the motor back together. What we have learned is that they do not give you any more peek power but it is the better power under the curve. We tried a simular idea with my brother car years ago and the car loved them. It helped it to the 8th but did not add any mph on top. We are looking forward to see how they work with Lens combo.
JAKES AUTOMOTIVE
[Re: jake4cars]
#461131
09/17/09 05:56 PM
09/17/09 05:56 PM
Joey
JOEY, NO HE SAID SHE SAID HERE.just the brutal facts. i proved about going 9.22 with a u tube video and since have gone faster. unlike the whompin woosie who cant get out of its own way with his 588, he puts up bogus irrelevant nonsense on here ruining another good post with immature rants with no relevence. if i had a 588 and went 9.79, id sell my junk. i had a 557 built by someone and it went 9.80's-that lasted about 12 passes before it came out and i went with a real engine builder. so whompin woosie get a all out video this weekend for all of us to see. man i feel like Larry Holmes against the great white hope Gerry Cooney.
#461132
09/17/09 06:13 PM
09/17/09 06:13 PM
I was at Pittsburg ready to race you...Remember this photo from the pits...
#461134
09/17/09 07:17 PM
09/17/09 07:17 PM
fortunately for you, my daughter was in a car accident the day i was leaving to open a can of whoop azzz at pittsburgh. why dont you come to atco, or etown and race me. i was at beaver springs, you werent.
this post was about 440-25 intake epoxy inserts. lets keep it on track. thanks
#461136
09/17/09 11:12 PM
09/17/09 11:12 PM
.....just the brutal facts..............
This "naysayer" is still waiting for you to answer my questions with brutal facts.........
Was it on the same day? If not, what was the DA between swaps?
How many converters have you tried in your car before the swap?
Have you dyno'd before and after, and what was the difference?
AGAIN, how can you claim that this is an easy, cheap trick that will pick up 1 and a half tenths on anyone's car that has that intake and installs those ???
I believe your car picked up with them, I just don't believe that you have enough facts to make claims like you're making.......
#461138
09/20/09 07:05 PM
09/20/09 07:05 PM
yea chris where is the answers???
anyways guys. We did try a set of them. figured it wouldnt hurt it at all.
First off even Ken at indy said there was no hp increase on the dyno, but it did pick the car up a few .01's in the 330.
We figured what the hell and put a set in. It was not a back to back test. We put them in Friday night after racing was done, and tried them saturday morning the air was 600ft better on saturday and the car only picked up .03 and 1mph. The air itself could have picked the car up that much.
All im saying is these things are not worth the .15 as claimed. But on the otherhand I dont thing they hurt the car at all... there isn't puddling in the intake now....
Also Im not the only one who tried them this weekend either, maybe others had better luck...
Casey
Oh and Chris, the reason you didnt come to the Pitt is because you didnt have your custom Mark Williams driveshaft back remember? Or was it you thought it was going to rain as your friend from New York came and told us? Oh well im sure there was a good reason none the less.
#461139
09/20/09 10:12 PM
09/20/09 10:12 PM
Casey, please explain this? 9.78 et you flyin now. i go faster than that starting in 2nd gear. please dont tell me throttle stops or running 10.0 class. thats pathetic. if your car was tuned better you'd pick up with those epoxy inserts. somethings wrong with that combo.
#461140
09/20/09 10:20 PM
09/20/09 10:20 PM
whats up with this?
#461141
09/20/09 10:30 PM
09/20/09 10:30 PM
With your obvious wealth of knowledge, you should try headsup racing instead of trying to go fast in a bracket class.......
and I'm still patiently waiting for replies to my questions...........
#461142
09/20/09 11:31 PM
09/20/09 11:31 PM
I would think that you would worry more about your own rides and getting them dialed in than worrying about how fast we are running. The class we run there is no advantage in buzzing the motor harder to run 9.50 or 9.25. So I choose to turn the throttle back and have a setup that I can get down the track. We are interested in winning rounds not posting home made videos on U-tube. There were 41 cars in the Max Wedge and probably twice that many in the 10.0 shootout so I need a setup that will be consistant for many rounds. I would think that this has been discussed enough..I am sure all the other board members could care less about how fast your car or my car runs and they are sick about hearing about it...Let's give it a rest and move on to something more constructive.
#461143
09/20/09 11:51 PM
09/20/09 11:51 PM
Casey
once again poppaj, your little boy starts the running his mouth. i put up a contructive informative post helping out guys with these indy inserts. it worked for me and i wanted to help out those who are looking for a little more. unfortunately for you, it didnt work. you give it a rest .
#461144
09/21/09 12:54 AM
09/21/09 12:54 AM
It is good to help with info I agree 100%..Casey's point was you need to test a part before claiming a .15 ET gain. That is substantial. They cost $175, most racers want to see test numbers before laying out the $$$.
