Page 1 of 4 1 2 3 4
All Indy 440-25 crossram users....... #461084
09/06/09 09:17 PM
09/06/09 09:17 PM
Anonymous OP
Anonymous OP
post up your jetting
metering jets, metering rods, metering springs, accelerator pump home placement.
and what jets you run.
also post your altitude where you run at, which is very important.
after everyone puts up your jets sizes, i will share a secret which will get you .15 faster ET with your combo.
a few select guys on here may know of the secret but ill share it with you anyway.
Re: All Indy 440-25 crossram users....... #461085
09/06/09 09:20 PM
09/06/09 09:20 PM
Anonymous OP
Anonymous OP
also forgot to add your cubic inch displacement.
Re: All Indy 440-25 crossram users....... #461086
09/06/09 10:00 PM
09/06/09 10:00 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
When I had mine(long ago) Kenny Lazari from Indy told me to jet them 113 square. I didn't run the manifold very long so thats how I left them. I always wondered why you wouldn't run larger primarys than secondarys due to the metering rods. The other thing I thought about was this. With the boosters being different sizes could they require more or less fuel to obtain the same fuel mixture in the primary and secondary sides? How about high speed bleeds to talor the entire fuel curve? I'm always looking for more info ontheses carbs. The new motor is 572,15-1,-1 heads,440-25 intake. I have both Cater Comp 750s and Eddelbrock 750s.
Doug
Re: All Indy 440-25 crossram users....... [Re: dvw] #461087
09/06/09 11:15 PM
09/06/09 11:15 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
out of the box 800's..... on a 492 CI
Re: All Indy 440-25 crossram users....... [Re: max_maniac] #461088
09/06/09 11:17 PM
09/06/09 11:17 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
might get one soon...
Re: All Indy 440-25 crossram users....... #461089
09/07/09 02:38 PM
09/07/09 02:38 PM
Anonymous OP
Anonymous OP
does it matter which carbs are being used?
Re: All Indy 440-25 crossram users....... #461090
09/07/09 04:06 PM
09/07/09 04:06 PM
Anonymous OP
Anonymous OP
works with both carter and edelbrocks, i just switched out a set of 750 carters to edelbrock 800's leaned them out a tad and went with a little richer metering rod for this weekend.
i feel it was too rich at launch only getting a 1.41 60 foot. and it slowed down 3 mph and .1 with 3 jet sizes richer.
i definitely thought the .116 jets would have woken the car up but no, even with half way decent air, it slowed down so ill be at .113 square for this weekend.
Re: All Indy 440-25 crossram users....... #461091
09/07/09 04:33 PM
09/07/09 04:33 PM
Anonymous OP
Anonymous OP
We are running .119sq. and the lightest springs and the large squirters. My 800's are highly modified, no air horns...They are worth .3 over stock 750's
Re: All Indy 440-25 crossram users....... #461092
09/07/09 07:52 PM
09/07/09 07:52 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Everyone I've talked to said the 800s were no better. Whats done to them? No air horns are supposed to be a NO NO. I personally think its a dumb rule. I would like to know what was done or who did them. Unless its a secret.
Doug
Re: All Indy 440-25 crossram users....... #461093
09/07/09 09:01 PM
09/07/09 09:01 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Ok now I'm confused you start this post letting us know that you have the secret to tune these carbs for a .15 better et and then you say you adjusted "yours" and you lose et so is this a trick post
Re: All Indy 440-25 crossram users....... [Re: dvw] #461094
09/07/09 09:09 PM
09/07/09 09:09 PM
Anonymous OP
Anonymous OP
They are a pair of Damon Kuhn 800's that have been massaged in the venturi areas, had mods done to the weights and to the fuel bowls along with several other internal mods. Pm me Doug if you want all the details....poppaj
Re: All Indy 440-25 crossram users....... [Re: max_maniac] #461095
09/07/09 09:24 PM
09/07/09 09:24 PM
Anonymous OP
Anonymous OP
Russ, no this is not a trick post, i already found the .15 increase, i was just looking to see if i could squeeze another .0500 out of the combo, i jetted it up some more figuring the air was a little better but it didnt work, so im going to try a jet configuration.
im looking for some more jet combos from a few more 440-25 members then ill all let you in on the easiest cheapest way to pick up .15
Re: All Indy 440-25 crossram users....... #461096
09/08/09 03:28 PM
09/08/09 03:28 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
We had 113pri-107 sec. went [Email]9.05@149.66[/Email] at 2800da.@3620 lbs.
JAKES AUTOMOTIVE
Re: All Indy 440-25 crossram users....... [Re: JAKE68] #461097
09/08/09 03:35 PM
09/08/09 03:35 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
my interest is peaked but i have never ran the combo
Re: All Indy 440-25 crossram users....... [Re: sixpackgut] #461098
09/10/09 08:53 AM
09/10/09 08:53 AM
Anonymous OP
Anonymous OP
Maybe you're talking about closing the rear throttle blades about 15*????.............
Re: All Indy 440-25 crossram users....... #461099
09/10/09 09:00 AM
09/10/09 09:00 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
cmon Chris.... I need to know quickly so I can test it this weekend.
Re: All Indy 440-25 crossram users....... #461100
09/11/09 06:57 PM
09/11/09 06:57 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
we're still waiting for the easiest cheapest way to pick up .15!!!!
thanks
Re: All Indy 440-25 crossram users....... [Re: old_racer] #461101
09/11/09 09:34 PM
09/11/09 09:34 PM
Anonymous OP
Anonymous OP
heres the pieces to put inside the indy crossram,they are made of epoxy sleeved with longer bolts.
they are going on my 500 ci motor in my 63 plymouth, this should get me right where i wanna be.
Re: All Indy 440-25 crossram users....... #461102
09/11/09 09:40 PM
09/11/09 09:40 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
And here all along I thought you were going to tell us all to join Jenny Craig I know I could lose a few lbs but not enough to gain .15 so, are you going to do a back to back test on these at the track to verify the .15 gain?
Russ
Re: All Indy 440-25 crossram users....... [Re: max_maniac] #461103
09/11/09 09:43 PM
09/11/09 09:43 PM
Anonymous OP
Anonymous OP
Russ
already have Russ on the 65 dodge, its a full .15
i had to get the other set before i posted, they've just made another run of them.
Page 1 of 4 1 2 3 4
