All Indy 440-25 crossram users.......
#461084
09/06/09 09:17 PM
09/06/09 09:17 PM
post up your jetting metering jets, metering rods, metering springs, accelerator pump home placement. and what jets you run. also post your altitude where you run at, which is very important. after everyone puts up your jets sizes, i will share a secret which will get you .15 faster ET with your combo. a few select guys on here may know of the secret but ill share it with you anyway.
Re: All Indy 440-25 crossram users.......
#461085
09/06/09 09:20 PM
09/06/09 09:20 PM
also forgot to add your cubic inch displacement.
#461089
09/07/09 02:38 PM
09/07/09 02:38 PM
does it matter which carbs are being used?
#461090
09/07/09 04:06 PM
09/07/09 04:06 PM
works with both carter and edelbrocks, i just switched out a set of 750 carters to edelbrock 800's leaned them out a tad and went with a little richer metering rod for this weekend. i feel it was too rich at launch only getting a 1.41 60 foot. and it slowed down 3 mph and .1 with 3 jet sizes richer. i definitely thought the .116 jets would have woken the car up but no, even with half way decent air, it slowed down so ill be at .113 square for this weekend.
#461091
09/07/09 04:33 PM
09/07/09 04:33 PM
We are running .119sq. and the lightest springs and the large squirters. My 800's are highly modified, no air horns...They are worth .3 over stock 750's
#461093
09/07/09 09:01 PM
09/07/09 09:01 PM
Posts: 6,354 Aurora, Oh.
max_maniac
Aurora, Oh.
Ok now I'm confused you start this post letting us know that you have the secret to tune these carbs for a .15 better et and then you say you adjusted "yours" and you lose et so is this a trick post
[Re: dvw]
#461094
09/07/09 09:09 PM
09/07/09 09:09 PM
They are a pair of Damon Kuhn 800's that have been massaged in the venturi areas, had mods done to the weights and to the fuel bowls along with several other internal mods. Pm me Doug if you want all the details....poppaj
[Re: max_maniac]
#461095
09/07/09 09:24 PM
09/07/09 09:24 PM
Russ, no this is not a trick post, i already found the .15 increase, i was just looking to see if i could squeeze another .0500 out of the combo, i jetted it up some more figuring the air was a little better but it didnt work, so im going to try a jet configuration. im looking for some more jet combos from a few more 440-25 members then ill all let you in on the easiest cheapest way to pick up .15
#461096
09/08/09 03:28 PM
09/08/09 03:28 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
We had 113pri-107 sec. went [Email]9.05@149.66[/Email] at 2800da.@3620 lbs.
JAKES AUTOMOTIVE
[Re: JAKE68]
#461097
09/08/09 03:35 PM
09/08/09 03:35 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
my interest is peaked but i have never ran the combo
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#461098
09/10/09 08:53 AM
09/10/09 08:53 AM
Maybe you're talking about closing the rear throttle blades about 15*????.............
#461100
09/11/09 06:57 PM
09/11/09 06:57 PM
Posts: 1,401 Wi.
old_racer
Wi.
we're still waiting for the easiest cheapest way to pick up .15!!!! thanks
[Re: old_racer]
#461101
09/11/09 09:34 PM
09/11/09 09:34 PM
heres the pieces to put inside the indy crossram,they are made of epoxy sleeved with longer bolts. they are going on my 500 ci motor in my 63 plymouth, this should get me right where i wanna be.
#461102
09/11/09 09:40 PM
09/11/09 09:40 PM
max_maniac
Aurora, Oh.
And here all along I thought you were going to tell us all to join Jenny Craig I know I could lose a few lbs but not enough to gain .15 so, are you going to do a back to back test on these at the track to verify the .15 gain?
Russ
[Re: max_maniac]
#461103
09/11/09 09:43 PM
09/11/09 09:43 PM
Russ
already have Russ on the 65 dodge, its a full .15 i had to get the other set before i posted, they've just made another run of them.
