Re: TTI exhaust install issues
[Re: moparsrule]
#461060
09/06/09 09:48 PM
09/06/09 09:48 PM
Posts: 2,763 Myrtle Beach, SC formerly the ...
340wedge
No, the starter wasn't an issue in my car (1971 Duster) but that block was hitting the exhaust when I moved the linkage into the gears, I think because the exhaust is slightly bigger in diameter, So I moved the block to the other side of the linkage that it attaches too. The kickdown wasn't a problem as it is a cable and was just slightly out of the way, it was next to the tranny cooling lines.
1971 Sassy Grass Green Duster 340 2006 Charger Daytona GoMango
[Re: 340wedge]
#461061
09/06/09 10:14 PM
09/06/09 10:14 PM
Posts: 4,872 connecticut
pnypwr
connecticut
a tti exhaust that doesnt fit? This cant be...Oh it must be your car was made different than everyone elses, thats why it doesnt work!! Couldnt possibly be that tti exhaust fits like garbage could it? I had a real treat of an experience getting it under my cuda...I sent it to the exhaust shop so they could cut it up and modify a 1000$ exh system.
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
