TTI exhaust install issues #461055
09/06/09 09:05 PM
09/06/09 09:05 PM
Hurricane, WV
moparsrule Offline OP
Hurricane, WV
I have a 74 Dart Sport with a 360 automatic with column shift and factory manifolds. I am installing a set of TTI 2 1/2" exhaust and it is hitting the passing gear linkage after I modified it like the directions shows, and I can not hook up the shifter linkage due to the pipe being in the way and the starter cables are will not allow the starter to go back on. Can anybody please help?
Re: TTI exhaust install issues [Re: moparsrule] #461056
09/06/09 09:10 PM
09/06/09 09:10 PM
Myrtle Beach, SC formerly the ...
340wedge Offline
340wedge  Offline
I'm not sure what you mean about the shifter linkage not being able to hook up? I just had to do mine and the stock linkage fit but I had to take the block that the adjuster rod slips through and move it to the opposite side to clear the exhaust. What part can't you hook up?
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
Re: TTI exhaust install issues [Re: 340wedge] #461057
09/06/09 09:16 PM
09/06/09 09:16 PM
Hurricane, WV
Hurricane, WV
The adjusting block that the rod goes thru will not go back in place and the passing gear linkage will not clear the pipe after modifing. Did you have to switch to the smaller race stlye starter to clear the pipe?
Re: TTI exhaust install issues [Re: moparsrule] #461058
09/06/09 09:30 PM
09/06/09 09:30 PM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
I had this problem with my 512 72 Challenger. I had to bend the lever from the floor shifter up IIRC then bend the rod going from the floor shift lever to the trans until it fit and worked smooth. The mini starter I had to remove the heat shields and bend the #1 tube so it was not directly on the starter they say that any starter will fit but it's only a couple of starters that actually fit I had 2 brand new ones and of coarse neither were the correct. one I love my TTI headers it's the best $800 I ever WASTED
Re: TTI exhaust install issues [Re: Boise Chall] #461059
09/06/09 09:35 PM
09/06/09 09:35 PM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
oops sorry I just noticed small block column shift neeeeeeevermind
Re: TTI exhaust install issues [Re: moparsrule] #461060
09/06/09 09:48 PM
09/06/09 09:48 PM
340wedge Offline
340wedge  Offline
No, the starter wasn't an issue in my car (1971 Duster) but that block was hitting the exhaust when I moved the linkage into the gears, I think because the exhaust is slightly bigger in diameter, So I moved the block to the other side of the linkage that it attaches too. The kickdown wasn't a problem as it is a cable and was just slightly out of the way, it was next to the tranny cooling lines.
Re: TTI exhaust install issues [Re: 340wedge] #461061
09/06/09 10:14 PM
09/06/09 10:14 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
a tti exhaust that doesnt fit? This cant be...Oh it must be your car was made different than everyone elses, thats why it doesnt work!! Couldnt possibly be that tti exhaust fits like garbage could it? I had a real treat of an experience getting it under my cuda...I sent it to the exhaust shop so they could cut it up and modify a 1000$ exh system.
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: TTI exhaust install issues [Re: pnypwr] #461062
09/06/09 10:19 PM
09/06/09 10:19 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Well I have it on both of my cars and it fit fine. One a 340 and one is a 440. No shakes or rattles and it doesn't leak. You may have to shim or move your motor a little to make things fit. The pipes are marked if you look close and alot guys miss that.
Re: TTI exhaust install issues [Re: Challenger 1] #461063
09/06/09 10:37 PM
09/06/09 10:37 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
440 TTI here. A little ding el doo ya. Just a ding for the pitman. Otherwise OK. Insatlled same time as motor.
