Necessary to run trans cooler? #460232
09/05/09 04:44 PM
09/05/09 04:44 PM
KY
juicedcuda Offline OP
KY
I would like to just put some flare caps on my transmission where the lines come out and run to the built in trans cooler on my radiator. The car is a pretty low stall but will see the track quite often and alot of street driving. No trans brake either. What's your opinion on not running a trans cooler?
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: Necessary to run trans cooler? [Re: juicedcuda] #460233
09/05/09 04:54 PM
09/05/09 04:54 PM
W.Va.
E
estcsthemi18 Offline
E
W.Va.
Don't block off the cooler lines, if anything run a loop between the cooler fittings. Oil from the cooler becomes lube oil for the planetaries. As for street, you should run a cooler of some type. Stay away from refigerator condensers and the like. Get a GOOD trans cooler from a local parts warehouse. Hope this helps.
Re: Necessary to run trans cooler? [Re: estcsthemi18] #460234
09/05/09 04:58 PM
09/05/09 04:58 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
a good remote trans cooler is like insurance for your trans. keep it cool & it'll last for years. get it hot & she's rebuild time in the near future.
Re: Necessary to run trans cooler? [Re: estcsthemi18] #460235
09/05/09 04:59 PM
09/05/09 04:59 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I run a B and M super cooler on my Charger,,,street/strip car....i didnt trust the rad to keep it cool enough.
Re: Necessary to run trans cooler? [Re: 69CHARGERMD] #460236
09/05/09 05:01 PM
09/05/09 05:01 PM
Q
Quicktree Offline
Quicktree  Offline
Q
heat being the number one killer of a tranny I would say yes. 83/4s are the number 2 killer
Re: Necessary to run trans cooler? [Re: juicedcuda] #460237
09/05/09 05:55 PM
09/05/09 05:55 PM
Most stock size low stall converters don't make enough heat to warm the ATF up to 160, that is one of the reasons that the factory run the ATF into the radaitor, to help warm the ATF up Go ahead and hook the lines up into the radaitor I have a freind (thumperdart) who post on here that installed a trans temp gauge in his trans and found that the trans wasn't warming up to 110F with a small, 3 coil, 10 inch by 10 inch, remote trans cooler mounted in front of his radaitor. H moved it to behind and below the front bumper so air would only pass over the top of it and not thru it, that allowed the temps to get to 160 F during the spring, fall and winter, it will go up in the summer to 180F in slow traffic His car was running mid to high tens with a 8 inch converter at that time.
Re: Necessary to run trans cooler? [Re: Cab_Burge] #460238
09/05/09 10:18 PM
09/05/09 10:18 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
REALLY ????
Re: Necessary to run trans cooler? [Re: Jeepmon] #460239
09/06/09 02:04 AM
09/06/09 02:04 AM
REALLY ????
Absolutely, I installed a trans. temperature gauge in my 1998 1/2 CTD 3/4 ton 2 wheel drice pick up, it never got above 120 F around town or out on the hiway empty, pulling my white 24 ft. enclosed car trailer with car in it, it would get up to 160 to 200 F if I was pulling a long hill in the summer like Techapi or Baker grade at 60+ MPH. Hopefully Thumperdart will chime in also to verify my memory BTW, a bad (cheap) converter will run real hot most of the time, unlike a good one
Re: Necessary to run trans cooler? [Re: Cab_Burge] #460240
09/06/09 01:15 PM
09/06/09 01:15 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Thanks Cab.. thats good information for when I pull the engine/trans out next time..
THanks
Re: Necessary to run trans cooler? [Re: Jeepmon] #460241
09/07/09 11:19 AM
09/07/09 11:19 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
run the fluid to the cooler first and then thru the radiators cooler. then the fluid will b e at engine temp and wont bee too cool.
Re: Necessary to run trans cooler? [Re: aarcuda] #460242
09/07/09 11:37 AM
09/07/09 11:37 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
The guy who had my digger before me ran a 727. He had deep aluminum finned pan IIRc 2+ quarts. Anyways he simply looped the lines with a section of steel line. He had a trans gauge, and is also a Trans builder. He said in drag racing no need for a cooler. The temp never got about 210 deg even after burn outs, and long staging battles.
Personally I run a cooler.
Re: Necessary to run trans cooler? [Re: Bob_Coomer] #460243
09/07/09 02:48 PM
09/07/09 02:48 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i bet that man never had a transbrake.
