Necessary to run trans cooler?
#460232
09/05/09 04:44 PM
09/05/09 04:44 PM
Posts: 761 KY
juicedcuda
KY
I would like to just put some flare caps on my transmission where the lines come out and run to the built in trans cooler on my radiator. The car is a pretty low stall but will see the track quite often and alot of street driving. No trans brake either. What's your opinion on not running a trans cooler?
1970 Plymouth 'Cuda
1970 Plum Crazy "Gold Duster"
1973 Gold Duster
Re: Necessary to run trans cooler?
[Re: juicedcuda]
#460237
09/05/09 05:55 PM
09/05/09 05:55 PM
Posts: 43,205 Bend,OR USA
Cab_Burge
Most stock size low stall converters don't make enough heat to warm the ATF up to 160, that is one of the reasons that the factory run the ATF into the radaitor, to help warm the ATF up Go ahead and hook the lines up into the radaitor I have a freind (thumperdart) who post on here that installed a trans temp gauge in his trans and found that the trans wasn't warming up to 110F with a small, 3 coil, 10 inch by 10 inch, remote trans cooler mounted in front of his radaitor. H moved it to behind and below the front bumper so air would only pass over the top of it and not thru it, that allowed the temps to get to 160 F during the spring, fall and winter, it will go up in the summer to 180F in slow traffic His car was running mid to high tens with a 8 inch converter at that time.
[Re: Cab_Burge]
#460238
09/05/09 10:18 PM
09/05/09 10:18 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
REALLY ????
[Re: Jeepmon]
#460239
09/06/09 02:04 AM
09/06/09 02:04 AM
Cab_Burge
REALLY ????
Absolutely, I installed a trans. temperature gauge in my 1998 1/2 CTD 3/4 ton 2 wheel drice pick up, it never got above 120 F around town or out on the hiway empty, pulling my white 24 ft. enclosed car trailer with car in it, it would get up to 160 to 200 F if I was pulling a long hill in the summer like Techapi or Baker grade at 60+ MPH. Hopefully Thumperdart will chime in also to verify my memory BTW, a bad (cheap) converter will run real hot most of the time, unlike a good one
[Re: aarcuda]
#460242
09/07/09 11:37 AM
09/07/09 11:37 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
The guy who had my digger before me ran a 727. He had deep aluminum finned pan IIRc 2+ quarts. Anyways he simply looped the lines with a section of steel line. He had a trans gauge, and is also a Trans builder. He said in drag racing no need for a cooler. The temp never got about 210 deg even after burn outs, and long staging battles. Personally I run a cooler.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#460243
09/07/09 02:48 PM
09/07/09 02:48 PM
Posts: 4,647 aotearoa
rebel
aotearoa
i bet that man never had a transbrake.
