Re: fiberglass on racecar questions
[Re: weedlayer]
#459829
09/06/09 09:59 AM
09/06/09 09:59 AM
Quicktree
hey Quicky, I guess you're the only one to ever install fiberglass on a racecar.
I guess so
[Re: Quicktree]
#459830
09/06/09 10:33 AM
09/06/09 10:33 AM
Posts: 3,210 robin hood country
deaks
robin hood country
I thought the bumpers were a piece of cake, i took half the brackets off and hole sawed the others to lose some weight, the hood is fairly straight forward if you use pins, rather than dzus fasteners, trunk I would use either, doors i dont know. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#459831
09/06/09 10:44 AM
09/06/09 10:44 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
As far as Lexan, depending on your car you might be able to find a kit but they are limited for the Mopar crowd.
I bought a sheet and did my own. It's real easy to do once you know what not to do.
