fiberglass on racecar questions #459825
09/05/09 09:57 AM
09/05/09 09:57 AM
CheddarHead till October
weedlayer Offline OP
so if steel fenders are removed, unbolted, spot welds drilled out, fiberglass just bolts on as the propaganda says?? no bonding or such? just bolt on?
fiberglass doors just bolt on using factory hinges, latches, bla, bla?? what about windows? I have seen where you can use factory regulators or others just use pins and lexan. can you get the lexan windows premade or do you make your own??
just some general questions while I decide what I may want to do.
Re: fiberglass on racecar questions [Re: weedlayer] #459826
09/05/09 10:05 AM
09/05/09 10:05 AM
Q
Quicktree Offline
Quicktree  Offline
Q
whats your goal Ray? are you trying to lose a little weight? glass is a PITA to fit and mess with. bumpers, replacing the glass, dorrs would be your biggest gain. I made my windows and I think I still have the templates. it's all very time consuming
Re: fiberglass on racecar questions [Re: Quicktree] #459827
09/05/09 10:19 AM
09/05/09 10:19 AM
I am repainting. Won't be done before I return to Fl, but will probably have everything except the doors and fenders done. The fenders were shot 20 years ago at the last paint, but were patched and came out ok. They are worse now, but can be salvaged for what I want. Just think while I am redoing it that it might be a good time for some new fenders and doors. I am not spending $500 each for steel fenders and then need to have someone install them.
and ya, it could stand to lose some weight while I'm at it. typical front end heavy Challenger.
am NOT looking for time consuming.
#1 goal is to just make it presentable again
Re: fiberglass on racecar questions [Re: weedlayer] #459828
09/06/09 09:39 AM
09/06/09 09:39 AM
hey Quicky, I guess you're the only one to ever install fiberglass on a racecar.
Re: fiberglass on racecar questions [Re: weedlayer] #459829
09/06/09 09:59 AM
09/06/09 09:59 AM
Q
Quicktree Offline
Quicktree  Offline
Q
I guess so
Re: fiberglass on racecar questions [Re: Quicktree] #459830
09/06/09 10:33 AM
09/06/09 10:33 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I thought the bumpers were a piece of cake, i took half the brackets off and hole sawed the others to lose some weight, the hood is fairly straight forward if you use pins, rather than dzus fasteners, trunk I would use either, doors i dont know.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: fiberglass on racecar questions [Re: deaks] #459831
09/06/09 10:44 AM
09/06/09 10:44 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
As far as Lexan, depending on your car you might be able to find a kit but they are limited for the Mopar crowd.
I bought a sheet and did my own. It's real easy to do once you know what not to do.
