Smallblock Distributor Rotor Phasing....
#455369
08/31/09 09:39 AM
08/31/09 09:39 AM
Posts: 419 NY
F1Scamp
NY
I searched on here and found the msd website on how to check it. Either I couldn't quite grasp it or it was a little vague. Using a stock electronic distributor, I drilled a decent size hole behind #1 terminal, Hooked the timing light up to #1 plug wire, shined the light through the hole while holding the rpm's around 3k rpm. The rotor was 1/4" to the right of the terminal, between #1 and #8 terminal. Using the adv. function of the timing light, I set it to 36 (what the timing is set to at 3000rpm, so if I look at the timing marks on crank it shows TDC) the rotor goes to approx 1/2" to the right between #1 and #8. It is even farther away from #1. To me, this looks bad. How do I fix this, oblong the holes that hold the ignition pick-up? Which way would I have to go?
Thanks guys.
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
Re: Smallblock Distributor Rotor Phasing....
[Re: mrsmallblock]
#455371
08/31/09 10:22 AM
08/31/09 10:22 AM
Posts: 419 NY
F1Scamp
NY
Thats what I thought. Can't run the different cap, I don't think the Fast guys would like that.
[Re: S/ST 3040]
#455373
08/31/09 11:35 AM
08/31/09 11:35 AM
Posts: 13,603 md
mopars4ever
md
[Re: AndyF]
#455379
09/01/09 07:35 AM
09/01/09 07:35 AM
Posts: 419 NY
F1Scamp
NY
So I should be looking at it with the timing light not advanced. It is around 1/4-3/8" to the right towards #8 terminal at 3k rpm. If I take the reluctor off, and get a new slot in it, which way would I go? To the right or left of the original slot? How far over? Anybody have an idea on where to start?
Thanks guys.
[Re: mrsmallblock]
#455380
09/01/09 12:23 PM
09/01/09 12:23 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Unless i am mistaken, MSD only makes those rotors for the Big HEI cap and not the normal small cap...or do they make them for both?
Howard
freind has pro billet?? he did his big improvment his was off a lot!
