Smallblock Distributor Rotor Phasing.... #455369
08/31/09 09:39 AM
08/31/09 09:39 AM
NY
F1Scamp Offline OP
F1Scamp  Offline OP
NY
I searched on here and found the msd website on how to check it. Either I couldn't quite grasp it or it was a little vague.
Using a stock electronic distributor, I drilled a decent size hole behind #1 terminal, Hooked the timing light up to #1 plug wire, shined the light through the hole while holding the rpm's around 3k rpm. The rotor was 1/4" to the right of the terminal, between #1 and #8 terminal.
Using the adv. function of the timing light, I set it to 36 (what the timing is set to at 3000rpm, so if I look at the timing marks on crank it shows TDC) the rotor goes to approx 1/2" to the right between #1 and #8. It is even farther away from #1.
To me, this looks bad. How do I fix this, oblong the holes that hold the ignition pick-up? Which way would I have to go?
Thanks guys.
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
Re: Smallblock Distributor Rotor Phasing.... [Re: F1Scamp] #455370
08/31/09 10:20 AM
08/31/09 10:20 AM
Dillsburg, PA
mrsmallblock Offline
Dillsburg, PA
The easiest way if you have room is to run one of the big HEI style caps because they make a indexible rotor for that and it makes it real simple. With just a regular stock cap and rotor, the only way to do it is file or elongate the holes in the cap and or rotor to achieve what you need.
Howard
Re: Smallblock Distributor Rotor Phasing.... [Re: mrsmallblock] #455371
08/31/09 10:22 AM
08/31/09 10:22 AM
NY
F1Scamp Offline OP
F1Scamp  Offline OP
NY
Thats what I thought. Can't run the different cap, I don't think the Fast guys would like that.
Re: Smallblock Distributor Rotor Phasing.... [Re: F1Scamp] #455372
08/31/09 10:26 AM
08/31/09 10:26 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I've seen some OEM electronic distributors with 3 key-ways in the reluctor.
It's hard for me to explain how you do it, even though I know what I'm saying.
Make sense?
Re: Smallblock Distributor Rotor Phasing.... [Re: S/ST 3040] #455373
08/31/09 11:35 AM
08/31/09 11:35 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: Smallblock Distributor Rotor Phasing.... [Re: mopars4ever] #455374
08/31/09 04:37 PM
08/31/09 04:37 PM
Dillsburg, PA
Dillsburg, PA
Wow, thats cool. never knew they made such a thing. I wonder if MSD makes an indexable reluctor like that?
Howard
Re: Smallblock Distributor Rotor Phasing.... [Re: mrsmallblock] #455375
08/31/09 04:50 PM
08/31/09 04:50 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
1st you don't use the advance feature on your timing gun 0 only better a straight single strobe.
Re: Smallblock Distributor Rotor Phasing.... [Re: Dodgem] #455376
08/31/09 04:58 PM
08/31/09 04:58 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
MSD makes indexable rotors.
now you could use the - feature on your timing light if it has one - till it lines up where you like and that will tell you how many degree's you have to move back to get lined up where you want.
Re: Smallblock Distributor Rotor Phasing.... [Re: Dodgem] #455377
08/31/09 05:04 PM
08/31/09 05:04 PM
Dillsburg, PA
Dillsburg, PA
Unless i am mistaken, MSD only makes those rotors for the Big HEI cap and not the normal small cap...or do they make them for both?
Howard
Re: Smallblock Distributor Rotor Phasing.... [Re: F1Scamp] #455378
08/31/09 05:10 PM
08/31/09 05:10 PM
AndyF Offline
AndyF  Offline
Hook up the vacuum advance and watch what happens to the rotor if you really want a surprise.
I started to re-machine reluctors a long time ago because of this very problem. The best solution for the stock distributor is to index the rotor so that you split the difference between the advanced position and the non-advanced position. If you keep the rotor close to the tower on average you shouldn't have a mis-fire situation.
Re: Smallblock Distributor Rotor Phasing.... [Re: AndyF] #455379
09/01/09 07:35 AM
09/01/09 07:35 AM
NY
F1Scamp Offline OP
F1Scamp  Offline OP
NY
So I should be looking at it with the timing light not advanced. It is around 1/4-3/8" to the right towards #8 terminal at 3k rpm.
If I take the reluctor off, and get a new slot in it, which way would I go? To the right or left of the original slot? How far over? Anybody have an idea on where to start?
Thanks guys.
Re: Smallblock Distributor Rotor Phasing.... [Re: mrsmallblock] #455380
09/01/09 12:23 PM
09/01/09 12:23 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Howard
freind has pro billet?? he did his big improvment his was off a lot!
