Re: Congrats Jyrki !!! HE GOT HIS CAR IN THE 7'S!!!
[Re: RonP]
#453826
01/22/10 02:11 PM
01/22/10 02:11 PM
Posts: 1,775 Marion, SC USA
69RR383
Marion, SC USA
I think everyone has already said enough, but WOW, you have got an amazing ride there. Great Job.
[Re: pade]
#453829
01/22/10 09:41 PM
01/22/10 09:41 PM
Posts: 7,497 Minnesota
Hemi_Joel
Minnesota
Good job, congrats! :thumb That is more impressive than you think.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#453830
01/23/10 05:38 AM
01/23/10 05:38 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
Thanks all! I consider what you FAST guys are dooing amazing. With my old four door in 1994 I run, I thought then, a pretty respectable 12.16/116.5 mph with 205/75/14 tires and 3.23 gears. Of course the engine wasn't stock, and not even close, but the chassis and suspension was. Then almost ten years later with the same car, gears and tires, but now maybe 250 hp more, I decided to try run ET's similar to yours. I only made three attempts in one race and the best I managed to do was 11.60 at 135 mph. It was pretty hopeless with teh ahrp throttle response and non existent traction, the best 60 ft was 2.000 and it wasn't until the end of the second gear that you could use full throttle. The same base engine, heads & block are now in the turbo VIP.
Plynouth VIP '67 TT IC EFI
[Re: smokinwoody]
#453833
01/23/10 08:46 PM
01/23/10 08:46 PM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
Nothing but awesome , nice job !
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: Avenger]
#453836
01/24/10 03:15 AM
01/24/10 03:15 AM
jyrki
Finalnd, Perkele
Thanks again, the current cam is on both sides of 260 degrees and 0.7" lift with 1.6:1 rockers and 115 LSA, and the new one should have considerably more exhaust degrees and even wider LSA. It's not done yet, so I donät know the exact specs.
