Convertible cylinder mounting bolt gone #451901
08/27/09 03:48 PM
08/27/09 03:48 PM
Springfield VA
GTXOnsfri Offline OP
Springfield VA
I have a 68 GTX convertible with issues. There is only one bolt holding the left cylinder down. I should say not holding down. I already have to replace the lines that were crushed when the cylinder moved up. Where can I get a replacement bolt and nylon bushing? All I can find on-line is GM parts.
Thanks!
Re: Convertible cylinder mounting bolt gone [Re: GTXOnsfri] #451902
08/27/09 04:02 PM
08/27/09 04:02 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
Check on E Gag. I know there is an outfit selling the entire replacement cylinders and they may have small parts also. Check out a Hemmings news magazine also, there is at least one conv top parts business that advertises there.
Re: Convertible cylinder mounting bolt gone [Re: Classof70Chally] #451903
08/27/09 04:06 PM
08/27/09 04:06 PM
BC
70RT27N Offline
70RT27N  Offline
BC
You could these guys a call:
http://www.convertibleparts.com/
Re: Convertible cylinder mounting bolt gone [Re: GTXOnsfri] #451904
08/27/09 04:16 PM
08/27/09 04:16 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
There is no bolt holding that cylinder... it has a clevis pin at one end & a bracket & nut in the middle... do you have the bracket? If so then possibly the stud is broken off that the nut attaches to...
Re: Convertible cylinder mounting bolt gone [Re: 1_WILD_RT] #451905
08/27/09 06:37 PM
08/27/09 06:37 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Whats the deal with the R O C K? I know I have seen quite a few pics here with it
Re: Convertible cylinder mounting bolt gone [Re: 340SIX] #451906
08/27/09 07:08 PM
08/27/09 07:08 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Rock was a line worker that liked to mark the cars he worked on... Pretty consistantly he scrbbled his name on the left rear wheel house...
Re: Convertible cylinder mounting bolt gone [Re: 1_WILD_RT] #451907
08/27/09 11:15 PM
08/27/09 11:15 PM
Springfield VA
Springfield VA
I tried the convertible service website with no joy. Tomorrow I'll call them. I posted a photo of cylinder. You can see where I added a bolt to temporarily hold the cylinder down. There is a bolt on the other side (with a ripped nylon bushing covering it). You can also see where the hose was crushed at the upper connection. I'll need to replace that also. I'm not sure I understand where the bracket is, unless the whole inner side is the bracket?
Re: Convertible cylinder mounting bolt gone [Re: GTXOnsfri] #451908
08/27/09 11:40 PM
08/27/09 11:40 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The whole outer plate is what I'm calling a bracket.. Instead of a bolt in that location there should be a pin.. it pivots on it so having threads creates wear points... If you look at the picture I posted above (gotta click the attachment for whatever reason) the pin has a large head on it which typically is tack welded to the plate/bracket... The same sort of pin should protrude from the top frame also.. Not a bolt....
And yeah you need hydraulic lines & replacing that cylinder wouldn't be a bad idea either... Come to think of it hey it's not my money, you should change them both...
Re: Convertible cylinder mounting bolt gone [Re: 1_WILD_RT] #451909
08/27/09 11:51 PM
08/27/09 11:51 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I had a machine shop lathe and install a missing pin in my keeper.. I believe convertible service makes the nylon bushings than install into the holes in the cylinders, before you install the pins....
Re: Convertible cylinder mounting bolt gone [Re: minivan] #451910
08/27/09 11:59 PM
08/27/09 11:59 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
On my Challenger I cheated.. The cylinders are the same size as the cylinders on a mid-late eighties K car convertible.. I found a real clean setup including the cylinders, lines & pump at Pick-N-Pull got it all for $35.00.. The cylinders have smaller holes where the center pivot goes so you don't use the bushings anymore, other than that it all is a direct bolt in.. Works well for my cheapskate nature... Unfortunately the 66-70 A,B & C body cylinders are longer though they all interchange with each other... So if you found a good A or C body setup... But A & C bodies are getting restored too these days so that pushes the new cylinders into a more needed status.. But the lines & pumps can still be salvaged from 80's & 90's Lebarons...
Re: Convertible cylinder mounting bolt gone [Re: 1_WILD_RT] #451911
08/28/09 04:55 PM
08/28/09 04:55 PM
London, England
Gavin Offline
Gavin  Offline
London, England
I had the same issue as you - prior owner had intalled a bolt. Also the hole they drilled was not centred. I drilled out the hole, tapped it and welded in a bolt with the correct diameter. To ensure alignment I bolted the bracket up to the top frame (it was off the car), put the bolt though both holes and welded in place. Then I cut it in half and shortened to size.
Re: Convertible cylinder mounting bolt gone [Re: Gavin] #451912
08/28/09 04:57 PM
08/28/09 04:57 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Nice Repair...
Re: Convertible cylinder mounting bolt gone [Re: 1_WILD_RT] #451913
08/28/09 05:08 PM
08/28/09 05:08 PM
London, England
Gavin Offline
Gavin  Offline
London, England
Nice Repair...
Thanks...like most things on this car I tried to do it right but it did take a bit of time
Re: Convertible cylinder mounting bolt gone [Re: 1_WILD_RT] #451914
08/28/09 06:59 PM
08/28/09 06:59 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: Convertible cylinder mounting bolt gone [Re: 69CoronetRT] #451915
08/28/09 10:37 PM
08/28/09 10:37 PM
Springfield VA
Springfield VA
Thanks, I have convertible service looking into a a bracket with a pin. I checked the other side and the pin was loose in that bracket and I can slip it out. I need to have that one welded back together too. I attached a photo of just the bracket. I'll use the bolt trick if convertible service doesn't have a replacement. Then it's on to the brake light switch that's way left of the pedal.
Re: Convertible cylinder mounting bolt gone [Re: GTXOnsfri] #451916
08/28/09 11:05 PM
08/28/09 11:05 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You should have two more pins attached to the top frame where the other side of the cylinder attaches...
As that pin is loose why not have a machinist duplicate it & then have them both welded to brackets...
Re: Convertible cylinder mounting bolt gone [Re: 1_WILD_RT] #451917
08/29/09 06:26 AM
08/29/09 06:26 AM
340SIX Offline
340SIX  Offline
I got a real clean pump and cylinders and hoses from a low mile Labaron vert early 90,s
My wifes old car before the old honda was a 93 red vert with black top gray guts and the 3.0
As soon as i looked at it i knew to keep a look out at the U pull it yard.
I got it all hopeing it would work in the E body and if not just the pump would.
So you are saying the pump,hoses and cylinders will all work in the Challenger/Cuda as well as B Body?
Re: Convertible cylinder mounting bolt gone [Re: 340SIX] #451918
08/29/09 10:38 AM
08/29/09 10:38 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Kevin unfortunately you got the later model parts, the square boxy K-car (83-88?) vert cylinders work, early 90's ie the rounder looking body style, you can use the pump & hoses but the cylinders are wrong...
Re: Convertible cylinder mounting bolt gone [Re: 1_WILD_RT] #451919
09/06/09 08:54 PM
09/06/09 08:54 PM
Springfield VA
Springfield VA
Ok, so here's the end result. Convert. Service had a bracket, but it was still attached to a complete frame that they didn't want to part out. I ended up fabricating a part for the bracket with a bolt and for $40, a convertible shop here in DC welded and cut the bolt. They also welded the right side barcket. I installed the brackets, new cylinder, and new lines. Just a little bit of air left in the lines. I cycled the top a number of times and it's nice to have a convertible again. Now I just need that new battery so I don't have to start the car to lower or raise the top.
One step at a time. Thanks for the tips.
