Re: Convertible cylinder mounting bolt gone
[Re: Classof70Chally]
#451903
08/27/09 04:06 PM
08/27/09 04:06 PM
Posts: 396 BC
70RT27N
BC
[Re: 340SIX]
#451906
08/27/09 07:08 PM
08/27/09 07:08 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Whats the deal with the R O C K? I know I have seen quite a few pics here with it
Rock was a line worker that liked to mark the cars he worked on... Pretty consistantly he scrbbled his name on the left rear wheel house...
[Re: minivan]
#451910
08/27/09 11:59 PM
08/27/09 11:59 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I had a machine shop lathe and install a missing pin in my keeper.. I believe convertible service makes the nylon bushings than install into the holes in the cylinders, before you install the pins....
On my Challenger I cheated.. The cylinders are the same size as the cylinders on a mid-late eighties K car convertible.. I found a real clean setup including the cylinders, lines & pump at Pick-N-Pull got it all for $35.00.. The cylinders have smaller holes where the center pivot goes so you don't use the bushings anymore, other than that it all is a direct bolt in.. Works well for my cheapskate nature... Unfortunately the 66-70 A,B & C body cylinders are longer though they all interchange with each other... So if you found a good A or C body setup... But A & C bodies are getting restored too these days so that pushes the new cylinders into a more needed status.. But the lines & pumps can still be salvaged from 80's & 90's Lebarons...
[Re: 1_WILD_RT]
#451913
08/28/09 05:08 PM
08/28/09 05:08 PM
Posts: 1,756 London, England
Gavin
London, England
Nice Repair...
Thanks...like most things on this car I tried to do it right but it did take a bit of time
[Re: 1_WILD_RT]
#451917
08/29/09 06:26 AM
08/29/09 06:26 AM
Posts: 28,604 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
I got a real clean pump and cylinders and hoses from a low mile Labaron vert early 90,s My wifes old car before the old honda was a 93 red vert with black top gray guts and the 3.0 As soon as i looked at it i knew to keep a look out at the U pull it yard. I got it all hopeing it would work in the E body and if not just the pump would. So you are saying the pump,hoses and cylinders will all work in the Challenger/Cuda as well as B Body?
[Re: 340SIX]
#451918
08/29/09 10:38 AM
08/29/09 10:38 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Kevin unfortunately you got the later model parts, the square boxy K-car (83-88?) vert cylinders work, early 90's ie the rounder looking body style, you can use the pump & hoses but the cylinders are wrong...
