Re: 727 trans shield [Re: dafixr] #450566
08/27/09 12:27 AM
08/27/09 12:27 AM
CHANDLER, AZ
512 VALIANT Offline
512 VALIANT  Offline
CHANDLER, AZ
I literally just received my CSR shield from Jegs today after nearly 3 months of backorder. It was $315 w/ no shipping and weighs nothing and is very thin. It will take up min. room to install. I returned a TCI flexplate shield for this reason and am very satisfied w/ the CSI.
Re: 727 trans shield [Re: formula S] #450567
08/27/09 12:33 AM
08/27/09 12:33 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
If you get a billet drum in there ... just use the MINIMUM "protection" that is required. You do NOT need that super-high-dollar and/or fancy-stuff since with the special-drums there is no possiblity of the trans ever coming apart.
I think you will need a shield no matter what is inside your trans in order to pass tech, it looks like 10.99 and quicker. Check out this link http://www.nhra.net/content/about.asp?articleid=34603&zoneid=101
f S .. I realize that .... hence my statement about the "minimum(NHRA legal)protection". I have a nice thick alum shield ...... and a nice lite-weight alum drum.
And how could the tech-guys KNOW what is really in the trans anyways ? .. they would have to assume you have the stocker-drum.
But anyways .. you guys with your CF shields ... you butter-your-bread any way you like.
Re: 727 trans shield [Re: dOc !] #450568
08/27/09 03:28 AM
08/27/09 03:28 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Is there a blanket that covers the bellhousing too?
I don't see much difference in cost?
$316 for CF cert for 5-years
$90 for blanket cert for 2-years ($225 for 5 years) + bellhousing/flexplate shield cost?
Re: 727 trans shield [Re: 451Mopar] #450569
08/27/09 06:02 AM
08/27/09 06:02 AM
San Diego
formula S Offline
formula S  Offline
San Diego
NO, and that is the reason for a shield. If you have a stock floor and fire wall the CSR type is all that will fit, and fulfill nhra requirement. The "thick aluminum" type wont fit the stock trans tunnel, and then you still need a bellhousing shield. Generally these items are for tube chassis door cars and dragsters.
Re: 727 trans shield [Re: WILD BILL] #450570
08/27/09 10:34 AM
08/27/09 10:34 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
I know, It's me
Everyone else has them fit the trans with no trouble, I go through 4 and none fit
Everyone else has them fit in their B bodies with out having to do much more than smak the lip of the firewall flat. Only way I get it in there is by cutting the tunnel out and fabing a new one
they must think im you,i dont have any better luck with them,and i dont have the luxury of trying it first
Re: 727 trans shield [Re: 451Mopar] #450571
08/27/09 10:44 AM
08/27/09 10:44 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
451 .....do you have a full explanation on the CERT-deals ? ... and how they figure out which one is good for a certain period of time or not.
THEN there is the cost of a re-CERT ? .. ??
Isn't this just another way for them to get into-our-wallets again and again ?
Re: 727 trans shield [Re: dOc !] #450572
08/27/09 11:33 AM
08/27/09 11:33 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
The CSI/CSR carbon fiber shield is also accepted
as a flex-plate shield.
Blankets, long or short do not and must have a
separate flex-plate shield to be legal.
A combination of flex-plate shield and blanket OR
the carbon fiber is required at 10.99 or quicker.
.......regardless of internals.
Don't forget CSR/CSI shields require removal of
OEM lugs on the bell housing.
Re: 727 trans shield [Re: S/ST 3040] #450573
08/27/09 01:27 PM
08/27/09 01:27 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Will the csr fit an a-body with bb trans?
Re: 727 trans shield [Re: sshemi] #450574
08/27/09 01:47 PM
08/27/09 01:47 PM
S/ST 3040 Offline
S/ST 3040  Offline
I have no idea......I don't run BB.
A SB 727 just does fit my Barracuda. Switched to a 904.
Re: 727 trans shield [Re: sshemi] #450575
08/27/09 01:50 PM
08/27/09 01:50 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I coudn't get it to fit in my B body w/ a BB trans.
Re: 727 trans shield [Re: sshemi] #450576
08/27/09 06:15 PM
08/27/09 06:15 PM
aZLiViN
J_BODY Online rolleyes
J_BODY  Online Rolleyes
aZLiViN
According to member Prosport...NO. He went with a blanket and a JW Utrabell. The ultra bell will satisfy the "flex plate, flywheel sheild" rule.
Re: 727 trans shield [Re: J_BODY] #450577
08/27/09 10:09 PM
08/27/09 10:09 PM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
remember to cut off those ears .Also the 727 big block and 727 small block look almost alike except the bell housing bolts are spaced apart a little .All those 2 piece trans bellhousing are crap even with a tunnel .
Watch the 904 jw bellhousing you have use a 727 ring ask me how i know
CSR
don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
