Re: 727 trans shield
[Re: dafixr]
#450547
08/26/09 12:37 PM
08/26/09 12:37 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Pretty much any parts supplier has them. Mancini Racing, Jegs, Summit, etc. $315.95 for the CSR shield from Mancini Racing. CHIP
[Re: dOoC]
#450549
08/26/09 03:09 PM
08/26/09 03:09 PM
an8sec70cuda
If you get a billet drum in there ... just use the MINIMUM "protection" that is required. You do NOT need that super-high-dollar and/or fancy-stuff since with the special-drums there is no possiblity of the trans ever coming apart.
If it's man-made, then there's always the chance of failure. Saying there's no possibility of it ever coming apart is ridiculous.
I'd much rather have the CSR shield than a blanket. CHIP
[Re: an8sec70cuda]
#450550
08/26/09 03:21 PM
08/26/09 03:21 PM
Posts: 30,443 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
OK Mr ..... tell us all here HOW that is possible.
You would have to have a engine capable of RPMing like a F1 motor to explode an aftermarket billet front drum.
Oh ...and I never said NOT running any safety equipment ...I just suggested that you did NOT have to empty-your-wallet to protect yourself.
[Re: dOoC]
#450551
08/26/09 03:27 PM
08/26/09 03:27 PM
Posts: 810 Sidney Ohio
9SecRoadRunner
Sidney Ohio
I'll stay out of the p*ssing contest, but aftermarket drum or not I have a good shield on my car....the CSR are nice, and the blankets can be a pain, but if you have a stock firewall and are using stock type motor mounts the shields can be a real bear when trying install the motor...I hammered the firewall/floor seem-lip flat and it was still a real PITA getting it in, I had to remove the motor mounts and position the engine in, then re-install the mounts once it was all in place, not a real enjoyable job...while doin this I would have traded the shield for a blanket..lol....this is just my experience...
You Thinking It's So Doesn't Make It a Fact
[Re: dOoC]
#450553
08/26/09 04:16 PM
08/26/09 04:16 PM
an8sec70cuda
Like I said, ANYTHING can fail. Whether it's billet or whatever, it CAN fail. Sure they are very strong and it's unlikely it would come apart, but saying it's impossible to blow one up is going out on a limb. CHIP
[Re: an8sec70cuda]
#450555
08/26/09 05:11 PM
08/26/09 05:11 PM
Posts: 1,090 north cakalaky
instigator
north cakalaky
And you think a glide won't explode...I have a co-worker/friend that has no case or drums left of a glide after it exploded...and this happened in reverse.
I too myself use a billet steel drum and CSI carbon-fiber shield to protect myself...though I did have the shield prior to replacing the drum...but I still use the shield also.
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
[Re: dafixr]
#450558
08/26/09 05:33 PM
08/26/09 05:33 PM
instigator
north cakalaky
Just crakin a little joke....I know you ain't elvis....hope your 7.80's comes around with a 400hit.
[Re: dafixr]
#450559
08/26/09 05:34 PM
08/26/09 05:34 PM
instigator
north cakalaky
Wouldn't mind knowing what goodies you have in the 727.
[Re: bonefish]
#450562
08/26/09 06:52 PM
08/26/09 06:52 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
if you get the CSR sheild MAKE SURE THE BOLT HOLES LINE UP!!!
I went through 4 of them with my trans down at Summit trying to get one tha lined up. None were even close. And after seeing those pics that were on here a while back where the drum went through the sheild, I'll stay with my blanket.
[Re: dusturbd340W5]
#450564
08/26/09 09:49 PM
08/26/09 09:49 PM
WILD BILL
BROOK PARK, OH
I know, It's me
Everyone else has them fit the trans with no trouble, I go through 4 and none fit
Everyone else has them fit in their B bodies with out having to do much more than smak the lip of the firewall flat. Only way I get it in there is by cutting the tunnel out and fabing a new one
[Re: dOoC]
#450565
08/26/09 10:45 PM
08/26/09 10:45 PM
Posts: 660 San Diego
formula S
San Diego
I think you will need a shield no matter what is inside your trans in order to pass tech, it looks like 10.99 and quicker. Check out this link http://www.nhra.net/content/about.asp?articleid=34603&zoneid=101
