727 trans shield #450546
08/26/09 12:25 PM
08/26/09 12:25 PM
Chicago land, IL
dafixr Offline OP
dafixr  Offline OP
Chicago land, IL
Where can I get a carbon fiber 727 tran sheild, and what is the cost? Want to get rid of the trans blanket.
Thank's JIM
Re: 727 trans shield [Re: dafixr] #450547
08/26/09 12:37 PM
08/26/09 12:37 PM
an8sec70cuda Offline
Pretty much any parts supplier has them. Mancini Racing, Jegs, Summit, etc. $315.95 for the CSR shield from Mancini Racing. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 727 trans shield [Re: dafixr] #450548
08/26/09 01:08 PM
08/26/09 01:08 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
If you get a billet drum in there ... just use the MINIMUM "protection" that is required. You do NOT need that super-high-dollar and/or fancy-stuff since with the special-drums there is no possiblity of the trans ever coming apart.
Re: 727 trans shield [Re: dOc !] #450549
08/26/09 03:09 PM
08/26/09 03:09 PM
If it's man-made, then there's always the chance of failure. Saying there's no possibility of it ever coming apart is ridiculous.
I'd much rather have the CSR shield than a blanket. CHIP
CHIP
Re: 727 trans shield [Re: an8sec70cuda] #450550
08/26/09 03:21 PM
08/26/09 03:21 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
OK Mr ..... tell us all here HOW that is possible.
You would have to have a engine capable of RPMing like a F1 motor to explode an aftermarket billet front drum.
Oh ...and I never said NOT running any safety equipment ...I just suggested that you did NOT have to empty-your-wallet to protect yourself.
Re: 727 trans shield [Re: dOc !] #450551
08/26/09 03:27 PM
08/26/09 03:27 PM
Sidney Ohio
9SecRoadRunner Offline
Sidney Ohio
I'll stay out of the p*ssing contest, but aftermarket drum or not I have a good shield on my car....the CSR are nice, and the blankets can be a pain, but if you have a stock firewall and are using stock type motor mounts the shields can be a real bear when trying install the motor...I hammered the firewall/floor seem-lip flat and it was still a real PITA getting it in, I had to remove the motor mounts and position the engine in, then re-install the mounts once it was all in place, not a real enjoyable job...while doin this I would have traded the shield for a blanket..lol....this is just my experience...
You Thinking It's So Doesn't Make It a Fact
Re: 727 trans shield [Re: 9SecRoadRunner] #450552
08/26/09 03:34 PM
08/26/09 03:34 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
P*issing contest ? ... not my intent at all. WHY NOT clear this matter up .. here and now. This has been discussed several times and I would like to know ... and I am SERIOUS ....
The fun-car that I am putting together (a FED) .. I am going to have a 727 BETWEEN MY LEGS ..and I want to build a trans that is bullet-proof(as far as exploding) ....
I ask this again ... How is any-type of explosion possible using an alum or billet-steel drum ?
Re: 727 trans shield [Re: dOc !] #450553
08/26/09 04:16 PM
08/26/09 04:16 PM
Like I said, ANYTHING can fail. Whether it's billet or whatever, it CAN fail. Sure they are very strong and it's unlikely it would come apart, but saying it's impossible to blow one up is going out on a limb. CHIP
CHIP
Re: 727 trans shield [Re: an8sec70cuda] #450554
08/26/09 05:10 PM
08/26/09 05:10 PM
Chicago land, IL
dafixr Offline OP
dafixr  Offline OP
Chicago land, IL
Thanks guy's I order 1 from Summit early today.$328.00 with shipping.
We are planning to run in the 7.80 class next month, didn't have any problems with the blanket just think that the trans will cool down faster.
496 Preadtor head Duster running 8.50's motor only,
going to spray a 400 shot to run 7.80 or faster.
JIM
Re: 727 trans shield [Re: an8sec70cuda] #450555
08/26/09 05:11 PM
08/26/09 05:11 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
And you think a glide won't explode...I have a co-worker/friend that has no case or drums left of a glide after it exploded...and this happened in reverse.
I too myself use a billet steel drum and CSI carbon-fiber shield to protect myself...though I did have the shield prior to replacing the drum...but I still use the shield also.
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: 727 trans shield [Re: instigator] #450556
08/26/09 05:14 PM
08/26/09 05:14 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
And from seeing his power level, can't be safe enough.
I thought eddies duster was purple!
65 Barracuda
Re: 727 trans shield [Re: instigator] #450557
08/26/09 05:18 PM
08/26/09 05:18 PM
Chicago land, IL
dafixr Offline OP
dafixr  Offline OP
Chicago land, IL
Eddie's in Florida, were in Chicago and run at GLD and Byron in the IMSM series. For what it's worth the trans is from Keith 727 specialist.
JIM
Re: 727 trans shield [Re: dafixr] #450558
08/26/09 05:33 PM
08/26/09 05:33 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
Just crakin a little joke....I know you ain't elvis....hope your 7.80's comes around with a 400hit.
65 Barracuda
Re: 727 trans shield [Re: dafixr] #450559
08/26/09 05:34 PM
08/26/09 05:34 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
Wouldn't mind knowing what goodies you have in the 727.
65 Barracuda
Re: 727 trans shield [Re: dOc !] #450560
08/26/09 06:06 PM
08/26/09 06:06 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
As Chip says, anything can happen. The billet front drums do not prevent the sprag from failing which is the reason the drum is spun up so fast in the first place. Along with the front drum, the sun shelll is also being rotated at 2.2 times engine speed. If the billet drum has a small flaw or the sun shell had a crack or a slight imbalance condition, either could explode after a sprag failure. The TCS testing shows their aluminum drum failing at a little over 22K which translates into an engine speed of 10K. Not that unrealistic if you have a sprag failure at launch when your right foot is planted on the floor. Sure, there's rev limiters, but there's always a chance that something may fail. Better safe than missing body parts!!!
Re: 727 trans shield [Re: PC-CHARGER] #450561
08/26/09 06:27 PM
08/26/09 06:27 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
if you get the CSR sheild MAKE SURE THE BOLT HOLES LINE UP!!!
Re: 727 trans shield [Re: bonefish] #450562
08/26/09 06:52 PM
08/26/09 06:52 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I went through 4 of them with my trans down at Summit trying to get one tha lined up. None were even close. And after seeing those pics that were on here a while back where the drum went through the sheild, I'll stay with my blanket.
Re: 727 trans shield [Re: WILD BILL] #450563
08/26/09 09:37 PM
08/26/09 09:37 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I must have got lucky had 1 shipped from CSR and it went right on to me the blankets are just to big and bulky and the CSR shield also acts as the flex plate shield and is cert for 5 years instead of the 2 years with a blanket
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 727 trans shield [Re: dusturbd340W5] #450564
08/26/09 09:49 PM
08/26/09 09:49 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I know, It's me
Everyone else has them fit the trans with no trouble, I go through 4 and none fit
Everyone else has them fit in their B bodies with out having to do much more than smak the lip of the firewall flat. Only way I get it in there is by cutting the tunnel out and fabing a new one
Re: 727 trans shield [Re: dOc !] #450565
08/26/09 10:45 PM
08/26/09 10:45 PM
San Diego
formula S Offline
formula S  Offline
San Diego
I think you will need a shield no matter what is inside your trans in order to pass tech, it looks like 10.99 and quicker. Check out this link http://www.nhra.net/content/about.asp?articleid=34603&zoneid=101
