TTI Header Install into a 340 A-body #441655
08/17/09 11:03 PM
08/17/09 11:03 PM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
Does anyone have a recomended procedure to install TTI one piece headers into a 340 A-body (duster) the only option is power steering, stock engine bay.
Any help appreciated!
Re: TTI Header Install into a 340 A-body [Re: ScottSmith_Harms] #441656
08/18/09 12:02 AM
08/18/09 12:02 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
i have installed two set of tti header on A bodies...read and follow instructions.
they were the easiest headers i ever installed.
Tony
70 AARCuda Vitamin C
Re: TTI Header Install into a 340 A-body [Re: 70AARcuda] #441657
08/18/09 12:35 AM
08/18/09 12:35 AM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
Remove the torsion bars will make it a whole lot easier to get them in and not scratch them.
Re: TTI Header Install into a 340 A-body [Re: SCATPK] #441658
08/18/09 12:58 AM
08/18/09 12:58 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
They are used, nice shape, no dents.....but no instructions. It does appear removing the torsion bars (at least the drivers side) will be an absalute must. Anyone have a copy of the directions they could e-mail me?
Re: TTI Header Install into a 340 A-body [Re: ScottSmith_Harms] #441659
08/18/09 02:29 AM
08/18/09 02:29 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
They used to have installation instructions on the TTI website, dunno if it's still there though.
Re: TTI Header Install into a 340 A-body [Re: Mcode69] #441660
08/18/09 03:24 AM
08/18/09 03:24 AM
No need to remove ANYTHING,just unbolt the motor mounts raise it to get clearance,unbolt the centerlink,headers slide right in,never heard of removing the torsion bar/bars... have installed tti's on 2 different cars,in less then an hour,each car,the best way is to install from the top,but you need the motor out of coarse..
Re: TTI Header Install into a 340 A-body #441661
08/18/09 03:59 AM
08/18/09 03:59 AM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
Agreed. Remove draglink. Unhook motor mounts, jack to drivers side, install passenger, jack to passenger, install drivers side. Re-assemble.
Cake walk.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: TTI Header Install into a 340 A-body [Re: topfueldart] #441662
08/18/09 05:06 AM
08/18/09 05:06 AM
wisconsin
kmfdm Offline
kmfdm  Offline
wisconsin
I installed some big tti W-2 headers on my Dart and all I did was tilt the motor on the side I was trying to install. I don't have power steering though.
74 Dart Sport
Re: TTI Header Install into a 340 A-body [Re: kmfdm] #441663
08/18/09 06:01 AM
08/18/09 06:01 AM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Besides the usual removal of the suspension items, I also removed the steering column (manual) which made the install a snap. I swaped out the 90 degree oil filter for the flush mount type. I did not remove the torsion bar nor did I tilt the engine. Tape up the torsion bar and other close contact areas. I did have to cut down the outside water jacket studs on the heads in order to bolt them up.
Re: TTI Header Install into a 340 A-body [Re: Pntastar69] #441664
08/18/09 11:21 AM
08/18/09 11:21 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Usually when I need to see instructions, I go to the manufacturers website. Surprising what you can find around those places.
I never pulled a T-bar when installing mine.
Re: TTI Header Install into a 340 A-body [Re: Pntastar69] #441665
08/18/09 11:29 AM
08/18/09 11:29 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Scott i had problems with my tti's hitting the P/S box. Directions state the correct distance from the center of crankshaft to top of the K frame is 5-1/4" and the engine should be offset to the pass side by 2-1/2" center of crankshaft to each frame rail. If not correct add shims between the insulator& K-frame mounting pad, Thats what i had to do on my Demon.
Re: TTI Header Install into a 340 A-body [Re: ademon] #441666
08/18/09 12:13 PM
08/18/09 12:13 PM
Locomotion Offline
Locomotion  Offline
These were also the easiest full body headers I ever installed. I actually got them in without removing anything but the starter. But the car was on a high open trailer with the deck open in the middle.
TTI A-body installation instructions.
