Re: TTI Header Install into a 340 A-body
[Re: ScottSmith_Harms]
#441656
08/17/09 11:02 PM
08/17/09 11:02 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
i have installed two set of tti header on A bodies...read and follow instructions.
they were the easiest headers i ever installed.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
#441661
08/18/09 02:59 AM
08/18/09 02:59 AM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
No need to remove ANYTHING,just unbolt the motor mounts raise it to get clearance,unbolt the centerlink,headers slide right in,never heard of removing the torsion bar/bars... have installed tti's on 2 different cars,in less then an hour,each car,the best way is to install from the top,but you need the motor out of coarse..
Agreed. Remove draglink. Unhook motor mounts, jack to drivers side, install passenger, jack to passenger, install drivers side. Re-assemble.
Cake walk.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: topfueldart]
#441662
08/18/09 04:06 AM
08/18/09 04:06 AM
Posts: 1,281 wisconsin
kmfdm
wisconsin
I installed some big tti W-2 headers on my Dart and all I did was tilt the motor on the side I was trying to install. I don't have power steering though.
74 Dart Sport
