Frozen WaterPump Housing Nipple #441161
08/17/09 06:13 PM
08/17/09 06:13 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Guys,
I have a waterpump housing of my 400 and I have ONE freakin nipple I cannot get out no matter how hard I try. I have sprayed the liquid wrench on it several times and clamped the crap out of it with vicegrips ...no luck.
I want to blast this housing and fit it with new nipples but this sucker is stuck tight! Any ideas?
Re: Frozen WaterPump Housing Nipple [Re: cjskotni] #441162
08/17/09 06:17 PM
08/17/09 06:17 PM
Any ideas?
Time to pull out the hot wrench
Re: Frozen WaterPump Housing Nipple [Re: RapidRobert] #441163
08/17/09 06:19 PM
08/17/09 06:19 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Any ideas?
Can you explain? You mean getting a blowtorch out and heating this up?
Re: Frozen WaterPump Housing Nipple [Re: cjskotni] #441164
08/17/09 06:21 PM
08/17/09 06:21 PM
N.E Indiana
repad Offline
super street
repad  Offline
super street
N.E Indiana
This is where a "heat wrench" (torch) comes in handy. If you don't have access to one, try placing a bolt in the nipple to give the vice grps something to grab.
Re: Frozen WaterPump Housing Nipple [Re: repad] #441165
08/17/09 06:25 PM
08/17/09 06:25 PM
yes with your acetylene torch & a small tip heat the threads until it starts to turn red, stop & with vice grips it'll come right.
Re: Frozen WaterPump Housing Nipple [Re: RapidRobert] #441166
08/18/09 12:58 AM
08/18/09 12:58 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
The last really stuck one I had, I used a ratchet handle (or anything steel) that fit snugly inside the tube, to keep it from crushing obround and with some propane torch got it hot.
Then used my vise grips and out she came..
Re: Frozen WaterPump Housing Nipple [Re: sthemi] #441167
08/18/09 01:05 AM
08/18/09 01:05 AM
USA
Rollin Hand Offline
Rollin Hand  Offline
USA
Cut it down almost flush with the housing then get out the drill bits and drill out the nipple to the point where you can chip out the remains.
Re: Frozen WaterPump Housing Nipple [Re: RapidRobert] #441168
08/18/09 03:10 AM
08/18/09 03:10 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The way to do it, forget about drilling it out.
Re: Frozen WaterPump Housing Nipple [Re: NANKET] #441169
08/18/09 10:27 AM
08/18/09 10:27 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Heat is the way to go.I did get a few out using wax.Heat the housing and nipple with a propane torch melt some bees wax at the threads.It works.Had T bar that would not move once.Used the wax and it came right out.If you have regular torches use them unless its an aluminum housing.Rocky
Chrysler Firepower
