Frozen WaterPump Housing Nipple
#441161
08/17/09 06:13 PM
08/17/09 06:13 PM
Posts: 1,526 North Carolina
cjskotni
North Carolina
Guys, I have a waterpump housing of my 400 and I have ONE freakin nipple I cannot get out no matter how hard I try. I have sprayed the liquid wrench on it several times and clamped the crap out of it with vicegrips ...no luck. I want to blast this housing and fit it with new nipples but this sucker is stuck tight! Any ideas?
Re: Frozen WaterPump Housing Nipple
[Re: RapidRobert]
#441163
08/17/09 06:19 PM
08/17/09 06:19 PM
cjskotni
North Carolina
Any ideas?
Time to pull out the hot wrench
Can you explain? You mean getting a blowtorch out and heating this up?
[Re: repad]
#441165
08/17/09 06:25 PM
08/17/09 06:25 PM
RapidRobert
yes with your acetylene torch & a small tip heat the threads until it starts to turn red, stop & with vice grips it'll come right.
[Re: RapidRobert]
#441168
08/18/09 03:10 AM
08/18/09 03:10 AM
Posts: 4,951 northwest USA
NANKET
northwest USA
The way to do it, forget about drilling it out.
[Re: NANKET]
#441169
08/18/09 10:27 AM
08/18/09 10:27 AM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
Heat is the way to go.I did get a few out using wax.Heat the housing and nipple with a propane torch melt some bees wax at the threads.It works.Had T bar that would not move once.Used the wax and it came right out.If you have regular torches use them unless its an aluminum housing.Rocky
Chrysler Firepower
