Rod Big End clearance problem?????? #440109
08/16/09 05:32 PM
08/16/09 05:32 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
I got cylinders 1 and 2 in my block. On the radius side of the crank I have .020+ But I can't get a measurement between the rods. Why is this? The rods should be able to move over as there is clearance on both sides of the pin end.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Rod Big End clearance problem?????? [Re: DemonDust] #440110
08/16/09 05:36 PM
08/16/09 05:36 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
If you have a radius ground crank instead of a factory one that has an undercut, you will need bearings that have a chamfer on them to clear the crank radius. The rods also have a chamfer on one side that goes to the crank radius as well.
Re: Rod Big End clearance problem?????? [Re: PC-CHARGER] #440111
08/16/09 05:49 PM
08/16/09 05:49 PM
Menomonee Falls
Menomonee Falls
Yeah, the chamfers are out toward the radius.
SDG Motorsports
Re: Rod Big End clearance problem?????? [Re: DemonDust] #440112
08/16/09 05:59 PM
08/16/09 05:59 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Sounds like the radius is too large for the amount of chamfer on the bearings. The bearings are riding on the chamfer which pushes the rods together and giving you the exact problem you are seeing. There will be a clearance at the radius side of the rod but they are forced together and no clearance between them. Here's a crude drawing that shows what's going on.
Either you have to have the radius reduced by re-grinding or the bearings will have to be scraped to fit.
Re: Rod Big End clearance problem?????? [Re: PC-CHARGER] #440113
08/16/09 06:12 PM
08/16/09 06:12 PM
Menomonee Falls
Menomonee Falls
I Remeasured everything. My journals are 1.8270 wide. My rods are .8900 wide.
The bearings are narrower than the rod. I'll try to get some pics.
Give me a few mins
SDG Motorsports
Re: Rod Big End clearance problem?????? [Re: DemonDust] #440114
08/16/09 06:24 PM
08/16/09 06:24 PM
Menomonee Falls
Menomonee Falls
Sorry for the poor pic quality.
SDG Motorsports
Re: Rod Big End clearance problem?????? [Re: DemonDust] #440115
08/16/09 06:30 PM
08/16/09 06:30 PM
Menomonee Falls
Menomonee Falls
With the caps off everything fits perfect, the rod will sit tight against the journal no problem. Maybe there is only .001-.002 clearance between my rods. I need to get a new feeler gauge, mine only goes down to .004
I'm thinking I may have to machine a little off the unchamfered side of the rod?
SDG Motorsports
Re: Rod Big End clearance problem?????? [Re: DemonDust] #440116
08/16/09 06:32 PM
08/16/09 06:32 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
The bearings are narrower than the rod as you have noted but it still appears the edge of the bearing is riding on the lower part of the crank radius. I would bet this is your problem and you may have to scrape the bearings slightly to make them work.
Re: Rod Big End clearance problem?????? [Re: DemonDust] #440117
08/16/09 06:33 PM
08/16/09 06:33 PM
Missouri
galen Online content
galen  Online Content
Missouri
Looks like edge of bearing is on the radius, if I am seeing pic correctly You will probably see a shiny spot on edge of the bearing where it is riding. You can buy a narrow bearing shell clearanced for this or chamfer them yourself.
Re: Rod Big End clearance problem?????? [Re: DemonDust] #440118
08/16/09 06:39 PM
08/16/09 06:39 PM
Menomonee Falls
Menomonee Falls
What is the best way to narrow the bearings?
SDG Motorsports
Re: Rod Big End clearance problem?????? [Re: DemonDust] #440119
08/16/09 06:47 PM
08/16/09 06:47 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Your picture is pretty tough to see but it looks like there is very little that needs to be removed. The proper tool is a bearing scraper like this:
http://www.etoolcart.com/bearingscraper.aspx
But if you go slow and easy, a good sharp knife and some patience will work.
Re: Rod Big End clearance problem?????? [Re: DemonDust] #440120
08/16/09 06:47 PM
08/16/09 06:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've cut them with a knife to increase the chamfer
Re: Rod Big End clearance problem?????? [Re: MR_P_BODY] #440121
08/16/09 06:51 PM
08/16/09 06:51 PM
Menomonee Falls
Menomonee Falls
Would a utility knife with a new blade do the trick?
SDG Motorsports
Re: Rod Big End clearance problem?????? [Re: DemonDust] #440122
08/16/09 07:05 PM
08/16/09 07:05 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Done carefully it will likely work. You just need to put a slight chamfer on the edge of the shell so that it clears the radius. Don't try to narrow the whole bearing.
Re: Rod Big End clearance problem?????? [Re: DemonDust] #440123
08/16/09 07:08 PM
08/16/09 07:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes... just light pressure.... your just scrapping it,
it scraps easy
Re: Rod Big End clearance problem?????? [Re: MR_P_BODY] #440124
08/16/09 07:28 PM
08/16/09 07:28 PM
south louisiana
lowell66dart Offline
south louisiana
Maybe practice with an old bearing first.
2021 Dodge 2500 4WD Cummins
2020 Challenger R/T Scat Widebody
2007 Charger R/T 5.7
Re: Rod Big End clearance problem?????? [Re: DemonDust] #440125
08/16/09 07:36 PM
08/16/09 07:36 PM
The Sunny Shuswap
dodgefarmer Offline
dodgefarmer  Offline
The Sunny Shuswap
Check to see if your bearings are marked upper and lower.
Randy
Re: Rod Big End clearance problem?????? [Re: DemonDust] #440126
08/16/09 08:16 PM
08/16/09 08:16 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
The measurements you gave for rod width and the width of the journal equates to.047 rod side clearance for that journal and pair of rods. Once you have the bearings scraped and you actually measure the side clearance, it will be .047. Anything less and the bearings likely need to be scraped a bit more. If you use this method to check the remaing throws, don't assume the same rod width and journal width. Measure them individually.
Re: Rod Big End clearance problem?????? [Re: dodgefarmer] #440127
08/16/09 08:18 PM
08/16/09 08:18 PM
Randy
same thing i was thinking. might have one or both in the wrong place.
Re: Rod Big End clearance problem?????? #440128
08/16/09 09:02 PM
08/16/09 09:02 PM
WA 98043
thecarfarmer Offline
WA 98043
You might want to throw a mic on the crank to make sure there's no taper on the journals. I had one that 'greew' .0015 (yes, one and a helf thousandths) from the oil hole to where the radius started.
Just something to look out for.
-Bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
